Question about Philips DVDR 3355 DVD Recorder
Phillips DVD Player / Recorder
Unit will not eject disc and displays 'blocked'
  • 4 more comments
  • Anonymous Dec 16, 2007
    Combo player will not eject DVD, what next? I am getting ready to get out the screw gun and go to work...
  • GLGJR Dec 29, 2007
    I took apart the DVD player and removed the unit that will not eject the disc.
  • Anonymous Mar 01, 2008
    my hdrw 720 keeps coming up with the error BLOCKED and won't open. How do I solve this? Is my DVD player/writer broken?
  • jacquis211 Jul 17, 2008
    disc tray will not open - no disc in - and displaying "blocked" what do i do?
  • yvonnemac Sep 07, 2008
    DVD wont do anything, just says its blocked
  • chiragsden Feb 22, 2009
    need the phillips hts 3010 player unlocking codes
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Posted on Jan 13, 2008
The DVDR 3355 at my home had the same problem and thanks God I found the solution. It's on this same forum at this address http://www.fixya.com/support/t353456-dvd_player
Posted on Oct 08, 2008
SOURCE:
I have a dvdr3380 player/recorder that when i want to eject disc shows blocked i tap top and it ejects.no problem feeding disc into machine or anything else.can you help.? also can i buy new dvdr3380...
The problem of your unit is the mechanical assembly. To resolve this problem, applying a small amount of grease in the sliding bracket can resolve the problem but be sure not to put grease in the pulley. In order to do this you should remove the cover of your dvd, then you can see the dvd rock remove the screw holding the dvd rock so you can pull out the whole assembly, but be very careful because you may damage the flex cable if you already remove the assembly try to look at the bottom and you can see the railings then you can apply grease. Note be sure to unplug unit before removing the cover. Good day and best regards.
Aug 08, 2011 | Philips DVDR3380/05 DVD Recorder
I have a Phillips HDD & DVD player/Recorder and when i try to open the try a sign comes up saying BLOCKED and I can't load a disc
Hi and welcome to the site,
Initially, postback with the model number.
BLOCKED as it implies indicates that the tray could not slide out; a common problem with some Philips models. Fix is to replace the DVD deck mechanism. Workaround is to always leave a disc inside.
Offhand, on most Philips models, there would be a manual eject slot at the bottom of the unit as shown in the representative image below.
Good luck and thank you for asking.
Jul 13, 2010 | Philips Televison & Video
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
I have philips dvdr3455h/37 when pressing eject shows blocked on the display i did press eject more than 10 seconds and still blocked?
What is "causing" the "blockage" is the stabilization idler mounted on a plastic piece spanning the top of the recorder. It is a plastic disc with a metal ring embedded in it. It clamps down on the DVD once its loaded. It is supposed to release when the eject sequence starts. The read/write head assembly is supposed to rise up to read a dvd or cd and drop back down to a rest position when its time to eject the disc. The head assembly is encased in a metal shell, which is already magnetized or has become magnetized. The mechanism pulling the head down is too weak to pull the head all the way down. It moves just a little bit, you hear some noise and the "blocked" message appears on the display. If you take the cover off, you see the dvd still in the "mounted" position, but it has moved a little bit, but the clamp effect of the stabilizer is still engaged
Two ways to fix this:
First, before you go inside, tap the area of the phillips case right where you imagine the dvd center to be, if one was loaded. Tap and hit open, you may break the magnetic link that way, the head drops, the tray slides out. Then always keep a dvd in the player to give the release motor a little help, use a scratched disc you were going to throw away anyway. Second, you need to open the case, pry the stabilizer up as high as you can, or tap on the plastic near its edge while pressing the "open" button. You may need a PC type screw driver to remove the very small screws that the stabilizer assembly is mounted on. This way you can at least get the disc without further damage to it. You might as well leave the screws off, if you plan to keep using the recorder. Click on the link below to download the user manual:
http://download.p4c.philips.com/files/d/dvdr3455h_37/dvdr3455h_37_dfu_aen.pdf
Jan 20, 2010 | Philips DVDR3455H/37B
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Dvd will not eject
This used to happen periodically with my unit. I would just unplug it and then whatever was stuck would pop out.
Jul 21, 2008 | JVC DR-MV1S DVD Recorder/VCR
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Philips DVDR 3355 DVD Recorder Logo
1,373 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
