Question about GE 25841GE3 5.8 GHz Twin Cordless Expansion Handset
Handset 2 show unavailable
Both phones are fully charged. Handset 1 works ok, but handset 2 beeps and shows unavailable
    New Friend:
  • 70 Answers
Hello
there is some battery problem with your phone please service it asap.
Posted on Jun 21, 2009
  • firdous mazhar
    firdous mazhar Jun 21, 2009
    hello
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Handset out of range
I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
(SYSTEM RESET)
Deregister HS
BaseUnavailible
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Yes
No
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Jun 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Handsets wont work at all
it may be that the handset is registred to another base unit-
we had one base and one handset replaced by uniden, but the second (old) handset was still registred to the old base, therefore everytime we tried to deregister the handset it was looking for the old (replaced) base and of course could not connect and therefore wouldnt deregister. still havent figured out what to do yet
Dec 20, 2008 | Lands Phones
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
GE 25841GE3 5.8 GHz Twin Cordless Expansion Handset Logo
280 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
