Question about Samsung DLP HL-P5663W 56" TV
A four year old samsung svc model HLP 5063WX/XAA, lam and standby lights blinking ever after new lamp, tuns on/off frequently. mechanic checked, no problem with blast and balance, is it power supply? if yes, how can i repair it myself?
  • gul786a Jun 24, 2009
    I had explained in my first question that as diagnosed by a mechanic, there is no power supply. I am again being told that there is a power supply problem. I need to know how to fix that power supply problem, I need a solution not a diagnosis.
  • gul786a Jun 29, 2009
    Hi
    The picture beside your name in your response looks of ballast, if it is so, and you are pointing a defect in the ballast, then as I said earlier the mechanic also changed the ballast but still it did not work. By the way, if you know some mechanic in Union County, NJ and whose charges are reasonable, I would like to engage him. Thank you for your help and guidance.
    Khan
    President:
  • 828 Answers
Power supply on it is low voltage, there's a two output there, the Primary and Secondary output, check the secondary output, this well give exact frequency of your HLP. And only electronics technician can see that but if you wanna fix, use the multi-tester and get voltage on its PCB. Advice, check Regulator. Good Luck!
Posted on Jun 29, 2009
  • 221 Answers
Take it appart, get to the power supply, measure low voltage outputs from the power suppl. You should notice that one of voltages shown on the circuit board doesnt exist, so track it backwards, until you'll reach the point where it dissappears. then just replace the deffective part (usually Power IC). Otherwise if all the voltages are like should be, then you'll need to digg deeper till the main processor ON/OFF controll line...
At this point I'd say that first make sure that voltage supply is just fine so you'll be able to digg deeper, as at the moment I'd give only 70% that it's power supply issue. But to digg any deeper you need to be sure that supply is fine. so get to work.
Update me about you progres, so we'll be able to work it out
Good luck
Posted on Jun 24, 2009
  • Samsung Master
  • 5,807 Answers
Have the power supply properly checked for output voltages, it may not have enough, to supply to the deflection board.it is in protection mode , unless the fault is repaired and corrected it wont turn on.you might be needing a multimeter to check for the voltages on the power supply and the horizontal output transistor.hope this help, thanks for using fixya!
Posted on Jun 21, 2009
  • Rommel Cana
    Rommel Cana Jun 23, 2009
    here is another compilation hope this help too., click on my name
    palaboy
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung model#hlr6167wx/xaa replaced lamp,lamp and standby/temp still blinking. the bulb is new and turns on. just no picture
Ballast Board needs to be replaced it is what turns Lamp on. 1-800-638-3328 Be sure that Lamp Fan is running or TV will not come on.
Jun 26, 2010 | Televison & Video
Replace Samsung Ballast BP47-00016A
ok sir go to www.fixyourdlp.com
over there you can find videos and a lot of stuff that can be interested 4 your self
Dec 18, 2009 | Samsung HLP5067W Television
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
