Question about Toshiba 36A50 36" TV
Toshiba 36zp18p/q television wont turn on, have checked power and fuse in plug, any ideas that wont cost me the earth?!!
  • opel17 Nov 23, 2008
    We have the same problem and we have two remotes that work but TV still won't turn on. We don't have any red lights turning on and off.
  • Anonymous May 03, 2009
    tv won't turn on and no red light by the on/off button.
The problem is your remote control. I have the same issue right now. The television is inoperable without a remote. Using the few buttons on the panel returns a response message of panel lock. Has anyone any ideas apart from buy a replacement remote ?
Posted on Aug 08, 2008
Same problem for me too - just a red light showing and nothing else.. sometimes it works but only about 1 in 100 :(
Posted on Apr 07, 2008
36zp18p
Video output stage circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 03, 2014 | Toshiba Televison & Video
TOSHIBA 55SL412U wont turn on
If fuse should blow up, surely there should be a resown for that. You must first check out the reason, and then insert an other fuse of same rating. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Check for damaged component/s at its main power supply regulator board.
Dec 22, 2013 | Toshiba 55SL412U LCD TV
Faulty toshiba 36zp18p
Surely the fault is with some loose contacts to any of the connectors with its sockets. Re-seat connectors one at each time, and check. Thus you can make sure about the loose contacted connection.
Nov 09, 2013 | Televison & Video
Hi My toshiba telly has suddenly died. It wont turn on or lights or anything, I have checked the fuse in the plug and that is about it
The Toshiba were well known for vertical issues and sometimes power supply problems, but in general are worth fixing. I suggest a technician at this point in order to narrow than the cause with an estimate in mind.
Jan 16, 2011 | Toshiba Televison & Video
Hi my nissan kubistar wont start and the glow plug light doesnt come on any ideas thanks
hi this could be a couple of thing, but sounds more like the heater relay is u/s, this is the one that heats the glow plugs before starting, check fuse box and see if fuse has blown first, but normally it would be the relay, the other thing could be a bad earth to the engine, check the earthing straps around the engine area, as one could be broken, also check the earth wire connection the heater rail to the plugs ( its the one that runs down the glow plugs and looks like a copper strip or similar ) check to see if is loose or broken...hope this helps please vote thanks
Jun 09, 2010 | 2004 Hyundai Tiburon
My Toshiba 27af44 wont turn on it has power Ive checked the fuse but it wont turn on
There are several, not very expensive, parts in the power supply that may have failed; some of them worth under a dollar. One does need some technical knowledge and two basic instruments to locate the failed part(s) however so the labor charge will be many times the parts cost.
I do recommend you have it repaired because when you decide to buy a flat-panel (LCD, plasma) type set, it will not likely last as long as your Toshiba has. The newer sets are being slapped together in China. I hope you have a surviving independent TV service shop in your area.
Jun 26, 2009 | Toshiba 27AF44 27" TV
No pic or sound with power on my Toshiba 50HX70 Tv
The plug configuration shouldn't make a difference; the third (round) pin is only an earth/safety ground. The two primary plugs supply the AC. You probably have a failed power supply which may be a separate board. Check to see if this is the case, look for a part number and see if you get any hits on it on search.
Jan 16, 2009 | Toshiba 50HX81 50" Rear Projection...
Sound problem with tv
Contqact trhe repairer who did the job- they obviously did not fix the probel - assumin it is the TV that is at fault- it could be reception, that is something only you can check.
Nov 08, 2007 | Televison & Video
Toshiba 36A50 36" TV Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
