Question about GE SpaceMaker 05GP009 Television
There is power to adapter but not in spacemaker unit
The geen light shows power on the adapter but the spacemaker unit shows no sign of having any power. I read somewhere it may be a fuse but don't see anything that looks like a fuse on the inside.
    Sergeant:
    Champion:
  • 255 Answers
Is there anything suspicious that you can see in the unit?like blown-out or busted? is the power switch on?
Posted on Jun 22, 2009
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of...
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
May 06, 2017 | GE Spacemaker 26976 Cordless Phone
Our Wii console will not power on and there is a disk in it.
Follow the directions below to see if this helps. If not, you may need to contact Wii technical support for repairs.
power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
Click here to contact Wii support
Regards,
G33k
May 05, 2011 | Nintendo Wii Console
My dell d610 sometime powers up in to xp then just freeze them sometime just 3 geen lights flash then nothing can you help
If there is a power issue, the first thing we need to determine is if it's the power adapter or the battery. Is there any difference if:
- You boot up with the battery in but the AC adapter not connected?
- You boot up with both the battery and AC adapter connected?
- You boot up with the AC adapter connected but the battery removed?
If different things happen for each of these scenarios, the problem is either a faulty power adapter or battery, depending on which one you can boot up without.
May 12, 2010 | Dell Latitude D610 Notebook PC
Wii console power light is not on. The console is plugged in.
Try the following (this was taken from Nintendo's website and the following link
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp
Also, see if you have a friend that has a Wii, and try their power cord on your unit. You may have a faulty cord.
Good luck.
Jan 19, 2010 | Nintendo Wii Console
Xbox showing no signs of life at ALL.
Hook up your power adapter to the wall and see if you get a green light, if you do then you know the power adapter is good. If you don't get a green light or you get an orange light then you know the ac adapter is bad and then get another one to hook up to the 360 and if you still don't get power then you know the main board inside of the 360 is bad.
Nov 30, 2009 | Microsoft Xbox 360 Console
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
GE PRofile Spacemaker 2.0 - power off
I would suspect the magnetron thermostat or the oven thermostat. In some models, they are called TCOs or thermal cutouts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 15, 2008 | GE Profile Spacemaker Over-the-Range...
Does hp 1040 fax have a fuse?
No, is there a geen light on the ac adapter? Is the AC adapter warm to the touch?
Mar 09, 2008 | HP 1040 Plain Paper Inkjet Fax
IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
GE SpaceMaker 05GP009 Television Logo
82 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
