Question about Canon imageRUNNER 400S Copier
Error E005 in canon ir400s - Canon imageRUNNER 400S Copier
    Sniper:
  • 118 Answers
Reset cleaning belt /web roller counter
* (with head)
2 and 8 (simultaneously)
* (with head)
on lcd press COPIER>Counter>Misc.Fixweb press (C)lear button Fix web counter must be 0000000
Switch power off and on the machine
Posted on Jun 24, 2009
  • meganathan
    meganathan Jan 27, 2015
    thank you its working....great
    Sergeant:
  • 199 Answers
E005
The fixing cleaning belt has been taken
up.
• The fixing cleaning belt has been
taken up.
• The image processor PCB has a fault.
The fixing cleaning belt drive solenoid has been driven more
than a specific number of times.
Fixing cleaning belt ---
Execute cleaning belt clear. ---
COUNTER>MISC>FIX-WEB
Posted on Jun 21, 2009
muleskinner2
  • 270 Answers
SOURCE: ir400
This is a fuser cleaning web ( FY1-1046-000 ) needs to be replaced error. After replacement of web you will have to go into service mode and reset the web counter to all zeros. Press additional function, then 2 & 8 at the same time, then additional functions again. At top and far right select counter, then MISC, then fix web, then "C" on keypad. Count should then be all zeros. Press reset key once and select function, CLEAR, ERR, then OK. Turn off copier and all should be well. Good luck.
Posted on Nov 20, 2008
Cogz
  • 1326 Answers
SOURCE: HOW TO CLEAR
A e005 means that the cleaning web needs to be replaced and you needed to reset the web counter in service mode.... Good Luck
Posted on Jan 16, 2011
SOURCE: E677 Error in canon IR400
canon ip board diagram for ir 400
Posted on Dec 22, 2009
SOURCE: Canon CLC800 error E005, How do I reset?
I have the same difficulties
please help me if you got solution
my E mail is:mabdi6325@gmail.com
Posted on Apr 27, 2010
Cogz
  • 1326 Answers
SOURCE: Canon Copiadora mi ir400 memanda
The error code means that the cleaning web for the fuser unit needs to be replaced and you must rest the web counter as well
Posted on Sep 15, 2010
My canon image runner 4005 (ir 330-405f) was connected to a network while i was formating my syste. The ip got deleted in it. What should i do?
check with network administrator for new ip or goto network settings and fetch ip by using DHCP.off/on the machine and thats it.
Sep 18, 2011 | Canon imageRUNNER 400S Copier
HOW TO CLEAR ERROR E005 IN CANON IR400 XEROX MACHINE
Jan 15, 2011 | Canon imageRUNNER 400S Copier
IR400 error E005. How do i solve
You need to replaced the fuser cleaning web and rest the web counter.
Sep 24, 2010 | Canon imageRUNNER 400S Copier
Canon Copiadora mi ir400 memanda E005 El error de no se quer signifique Como desbloquearla o de soja Por favor ayudenme nuevo en ESTO
Sep 15, 2010 | Canon imageRUNNER 400S Copier
I have replaced le fusing cleaning WEB but the error code E005 is still displayed when I switch on the copier CANON ir400. What can I do to reset the error code. Thanks
You have to get into service mode and go to the counters and go to the web counter and reset it. Also, You may want to go to the Funcation mode and reset the error codes also. To lock the counters, turn the main power switch OFF then back ON.
Aug 30, 2010 | Canon imageRUNNER 400S Copier
IR400S copy counter location
inside the front cover on the left side
Jan 05, 2010 | Canon imageRUNNER 400S Copier
We have a Canon IR400S with the following error message - Switch main power on & off, E005. Switching power on & off did not clear error. Can you tell me what the error message means?
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
Dec 10, 2009 | Canon Office Equipment & Supplies
Ir400
Nov 18, 2008 | Canon imageRUNNER 400S Copier
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
619 people viewed this question
old marine
old marine
