Question about Instek Power Supply, Triple Output, DC, Digital, 30V, 3A Power Supply
Emachine-adjusted resolution to high cant get back to home page
I tried to adjust the resolution on my computer and I set it too high and now I cant get back to my home page to reset it. I don’t want to do a repair as I have a picture file I don’t want to lose.
While restarting your computer press F8. you get multiple option windows. choose enable vga mode
Posted on Jun 26, 2009
I have set the screen resoloution to high for my monitor and now get a message saying "screen resoloution to high set to 1680 x 900" but cant reset it as all i get is the message and a blank...
First try shutting system down, unplug tower for 1 minute and restart. Give it time to come up and if that doesn't work, shut it down again and try to start in "safe mode" do you get any screen at all? If you can start in safe mode try going to "control panel'", "device manager" then "personaliztion", and adjust your resolution. If you can't adjust your resolution in safe mode do a "system restore" back to when monitor worked.
Apr 04, 2011 | Computers & Internet
Computer monitor out of range is being flashed on screen
Monitor is not recognizing the resolution settings that are currently set on the computer.
It is probably sett too high.
You will have to lower the computer resolution.
If it is a laptop, you should be able to do this using the laptops screen.
If it is a desktop computer, you either have to use a different screen to reset the resolution.
or
Sometimes restarting the computer while the screen is on will reset the video.
If that doesn't work, try starting the computer in safe mode by tapping the F8 key while it is being started. This will keep the resolution low enough to see it on the monitor and you can adjust the resolution there in the display properties
Oct 19, 2010 | E-Machines eMachines Monitor E15T4
My image on the monitor is streched. Out of proportion.
The screen resoultion may be set too high.
Go to Control Panel - Display - click on the Settings tab, then adjust the screen resolution to 1024 x 768 to see if the proportion is OK, if not then adjust the next higher setting until the proportion is OK.
Jul 01, 2010 | Acer eMachines 520-2890 Notebook
Can't maintain high graphics resolution on new LG monitor
Are you sure that you are "setting" the resolution correctly? After you set a higher-resolution, there should be a "test" window ("if you can see this, click OK within 15 seconds"). Click 'OK' (or is it 'Apply' ???) within the 15 seconds.
Then, click 'OK' to close the 'Properties' window.
Jan 15, 2010 | Computers & Internet
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
The letters on my computer r so small i cant read them, how can i make them bigger
You likely have your resolution too high.  I prefer my resolution high but I can read small writing easily.   To change this right-click your desktop and choose personalize then display settings  adjust to a lower resolution but try to keep the aspect ratio similar to the ratio of the monitor you are using or the image will look squished.  once you have finalized your decision you will have to tweak it using the controls on your monitor to stretch the picture out to the edge of your monitor.    Also you can use the ease of access in the control panel for an on screen magnifier, or simply increase the font size in personalize (left column) adjust font size (DPI) (dots per inch)
Nov 17, 2009 | Microsoft Windows Vista Home Premium with...
How do I adjust my monitor? My home page does not
I'm not sure what operating system you're using nor what you mean by your "home page". If you mean your browser window doesn't fill the whole Windows desktop, what happens when you maximize the window?
If your desktop looks huge with tiny icons (and tiny-looking windows, if you have any open and not maximized) all clustered in the middle of the screen, your display resolution may be set higher than you're accustomed to. In most versions of Windows you can go to Control Panel | Display, see what your current resolution is, and try adjusting it. The higher the numbers, the "bigger" the desktop area (and the smaller the icons and everything else). If you adjust the resolution higher than your monitor can handle, you may lose your display and have to restart the computer in something like Safe mode to get to Control Panel and readjust it. If you adjust the resolution lower (or run in Safe Mode) your icons may not fit on the smaller desktop and may get scrambled. In that case, first straighten out the display resolution, then move your icons back where you want them.
Jun 14, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
I can't open my desktop and it tells high resulotion!
first open the properties of your destop then click the link containing the desktop
Mar 22, 2009 | MPC Computers Micron Transport LT Series
Setting resolution
Adjusting the resolution is done in Windows. Right click on the desktop and click on properties. Once that opens click on the Settings tab. There you will have a slider bar that you can adjust your resolution with. As far as being able to see things clearly on the monitor, the best picture is usually obtained simply by pushing the AUTO button.
Dec 05, 2008 | E-Machines 17" Widescreen Flat Panel LCD...
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Instek Power Supply, Triple Output, DC, Digital, 30V, 3A  Power Supply Logo
94 people viewed this question
Top Instek Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Instek Computer and Internet Expert? Answer questions, earn points and help others
