I have removed the inner tub from the spindel and can hear water sloshing around. is this normal
SOURCE: Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
SOURCE: Spin Shake ...
HI-
I have a 3 year old front load Danby washer and it started making load scraping noises during the spin cycle. Any idea what this may be? Can I fix this myself as I don't want to buy a new one just yet.
Thanks!!!
SOURCE: washing cloth diapers
You could, however do not add above the bottom of the door glass. I do this alot on our machine. also use the extra rinse option.
SOURCE: Water remains in tub after spin cycle
Hi, a small amount of water in the tub is normal, between the inner and outer drum. As long as it's below the inner drum you're ok. If it's a front load this is a common smell. Just make sure you dry the rubber seal and leave the door open a little to allow air to circulate through the washer.
