Question about Samsung Televison & Video
Samsung wide screen HCN5527W tv reset
I have lost my manual . . . and I believe all i need to do is reset the tv
help
My Samsung model PS42P3SX/XWU has no sound coming from it from the Sky+ box, just picture. Was working then stopped. DVD connection is ok.
Posted on Jul 21, 2009
Manual for Samsung smart TV needed model number UN55F6350AF
E-MANUAL - samsung product support network
support-us.samsung.com/.../201306131733051%5E...
Samsung Electronics97 Sound Feedback. 97 Panel Locking. 97 Booting Logo. 97 DivX® Video On Demand.SMART TV Features. Smart Hub. 98 Agreements Required to Use Smart ...
Official Samsung Support
www.samsung.com/us/support/
Samsung Electronics... visual guides, manuals, support downloads, tech specs, troubleshooting, and answers. ... TV & Video. Televisions ... TV & Blu-ray Apps ... Smart Home. Outlets.‎Samsung Galaxy S® 6 - ‎Samsung Downloads - ‎Contact Us - ‎Wi-Fi Tabs SM-T800
Samsung UN55F7500 Flat Panel Television User Manual
tv.manualsonline.com > ... > Samsung Flat Panel Television
Jan 27, 2016 | Samsung Televison & Video
HCN5527W Samsung wide screen 55" will not turn on, scree went black unit 4 1/2 years old
picture tube pro...so pls change ut picture tube and use...and also due to some fluctuation it may cause tis pro so try to plug ur pin in some other slot in ur home
Aug 29, 2008 | Samsung HCN5527W 55" Rear Projection...
NEC Rear Projection TV has sound but lost picture
CK your Hori output Transistor if it is shorted high voltage will shut down
Dec 21, 2009 | Samsung HCN5527W 55" Rear Projection...
The picture has lost focus and lost green
hard to say for sure, but the front opens up when you remove the bottom or edges. inside you need to inspect the CRT boards for any fluid leaks. there are focus adjustments on a black controller with 3 knobs on it. I would say take a look at the middle tube (green tube) if its dark and the circuit are dry. Try cleaning the CRT pins with the TV off, simply pull the cba/socket down and push it back up.
so lets see no green tube lite , cleaned pins no fluid, next tap it to see if it flashes bright, no OK now on the grn CRT circuit board slowly TV ON turn up the control you see and see if the green gets brighter. The CRTs are fluid filled and the fuild can get cloudy causing it to get dark and blury too. to check the fluid you would need to pull the screen off (a real pain)
these steps will help you isolate the isue and decide what to do next, hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 26, 2009 | Samsung HCN5527W 55" Rear Projection...
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Samsung hcn5527w convergance factory reset
Sorry, I just saw this post.
I hope this helps.
Yes there is one more step. You should call the technician out and have them set up the Magic Focus adjustments. I have serviced these televisions for years and I have made this mistake and had to return to fix it. You should not have to pay for a rework. The technician should have done the complete job the first time.
I hope this helps
and good luck.
asnowman
Mar 19, 2009 | Samsung HCN5527W 55" Rear Projection...
Picture adjustment??
you may need to adjust the convergence check to see if you can move the alignment squares
Mar 16, 2008 | Samsung HCN5527W 55" Rear Projection...
I need help!
Michael,
the problem you are having is caused by bad convergance amplifiers along with open pico fuses internal to the set. these amps range from $45.00 to $65.00 each and both amps need to be replaced. this is a common problem with rear projection sets. these amps work very hard and are kept cool on large heat sinks. so with that a tech is needed to repair. techs may charge $150.00 to $350.00 for the labor. so shop around. as for the adjustments you made let the tech know because you may have set the settings far out of the range for the set and will cause shut down before it can be reset. the tech will know what to do. to find a factory athorized repair shop call samsung the number is in your manual or on line.
Bob Johnson
Dec 31, 2007 | Samsung HCN5527W 55" Rear Projection...
Bad picture
The STK392-040 Is Convergence correction circuit! but the question is... what is the result when he replace the said parts? ok lets see... the probs. of your TV is a small parts like capacitor maybe this capacitor has change of value thats why the convergence is not in align...
Sep 14, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung projection tv
Elissa, unless you have some basic electronics experience probably not, what your describing is one of the most common projection tv problems there is, but it will require replacing a few components on a circuit board. You will need to solder and possibly check resistance values of a few resistors. I will say there is no need for a samsung servicer, any tv repair place will know how to repair this problem. Probably will cost around 300 if you have somebody to your home. I don't think your looking for the Technical details but if so replace the 2 large STK amplifiers probably (STK392-040) and test all resistors and fuses in input/output ckts, replace accordingly.
Apr 25, 2007 | Samsung HCN5527W 55" Rear Projection...
Televison & Video Logo
162 people viewed this question
Jerry Greenberg
Jerry Greenberg
