Question about Lomanco PCVI POWER CRAWL SPACE VENT Fan
Humidity build up in crawl space
Would putting a fan at one end of the crawl space vent to draw outside air in and putting two vent fans on the opposite end help circulate the air so there would be good circulation in the crawl space help to drive the humidity out.
  • 1 more comment
  • thomas_sm520 Jun 22, 2009
    i have two vents which have a 110 cfi fan in each controlled by a humidstat.The crawl space is 1680 square feet and 5 feet in height.I am considering getting another two fans which are actually two fans on a metal sheet which fits behind a vent controlled by a humidistat.these cans put out 220 cfi!s.if i do put this double fan in where would i put it.
    I dont think you realize that my basement structure has cinder blocks so i dont understand how i can have a hinge system,therefore i cant install a door.As far as the cutoff switch i think my humidstat would accomplish that.Now as far as the fans is concerned both of the fans i now have installed at one end of the crawl space are naturally sucking air out which is their purpose.Are you saying that i should install two fans at the opposite end of the crawl space to cause the air to move.We do live in a humid envirement as tennese has that nature.
    The one big problem i had was direction of the air flow and by communicating with your experts i found out that the air flow of the fans has to be in one direction rather than putting fans on the side of the crawl space area which would curtail the air flow .Thanks
  • 4,806 Answers
The best places is at opposite ends of the crawl space on a hinge system so you can open and close them like doors for easy access.
Put one of them near the outside but backwards so the fan sucks air out instead of in, that will certainly keep the humidity down while working in the crawl space.
If you do erect the fans in this way make sure you install a safety cut out switch on fans for safety and maintenance purposes.
Regards
Posted on Jun 22, 2009
  • Lee Hodgson
    Lee Hodgson Jun 22, 2009
    Yes, one ore two fans at each end will do the job, also installing a ceiling fan in your basement would maximize airflow around the basement as the ceiling fan will push the heat down towards the main extractor fans that you have installed, the hot air can only go one way which is out.
    I wouldn't have the fans sucking in air from the outside as the humidity will only get worse, you need to move the air inside the house as much as possible to keep the humidity down to a comfortable level.
  • 19,396 Answers
A fan at one end of the crawl spacecan help, but to vets at the two sides wont work. The fan must rotate in same direction of the vent currently there.
A much better and clever solution is using a de-humidifier near to the unit.
see Buy Dehumidifiers & Portable Dehumidifiers.
regards
I have a fridgedaire dryer, front loader. It gets wet inside on the door down through the lint filter, under the drum and out the exhaust. Think the problem is with the vent but can't figure out why. ...
2 questions are there more then 3 elbows in your vent run
and is any of it flexible pipe?
Humidity will infiltrate but should be infiltrating that much. One thing they make for dryer vents is a flap that opens one way to let air out, while dryer is running and closes when dryer is off. I don't think its humidity causing your issue. When you say the vent is straight does it run horizontal (even with the floor) or does elbow down and then run straight/horizontal?
Also about how long is the pipe run?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 22, 2013 | Frigidaire FDE336RE Dryer
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
Oct 19, 2017 | GE JVM2070 Microwave Oven
How do I install a basic vent system to create air flow in my basement?
Your air circulation knob or switch has 2 settings ,recirculate and fresh air,turn to fresh air,put on cold and turn the fan on to your speed you want and air will circulate from the outside to the vents,put it on mid level.
Jul 22, 2012 | Cars & Trucks
My carrier heat pump has frosting on the outside on it's coils. I know that it's cold outside but is that normal?
Yes it is normal especially with high humidity. The moisture freezes on the coils just like on the evaporator coils in a freezer. The heat pump will defrost itself by shutting off the fan outside and reverse the flow of refrigerant to melt the ice when it build up then switch back to normal heat. That's why at times you may feel cold air coming out of the vents in the house. The outside coils are defrosting.
Dec 16, 2010 | Heating & Cooling
This summer I have ice build up on top of the unit. I have a drain hose so the bucket is not full. I have cleaned the air filter. I have also removed the front grill and used a fine brush to remove dust...
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils.
To remedy this problem, you can try any of these:
Warm up the room the dehumidifier is in.
Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Take care.
Aug 12, 2010 | LG LHD45EL Dehumidifier
Emerson quiet kool wall air conditioner. Should vent be open to remove humidity?
No - opening the vent will allow unconditioned outside air into the space and add to the humidity load.
Think of it like your car's A/C - when you put the controls to "Max A/C" the system recycles just the air inside the car and doesn't use any outside air. When the control is set to normal A/C, some outside (fresh) air is brought in.
The same thing is true for a window A/C unit. Keeping the vent closed will help the unit de-humidify and cool the air more quickly.
Jul 12, 2010 | Emerson Quiet Kool 12NW46K Air Conditioner
What is the lowest temperature I can maintain with this heater ? That is, I plan to use it in crawl space where water pump and pressure tank and copper pipes and water heater are located and in winter...
YOu are asking a question that cannot be properly answered without knowing more of the situation. If this crawl space is subject to large air drafts and there are air vents that allow openess to this area, then you cannot be sure of the results. Since it will be winter, the humidity build-up is not so much a factor and you should take steps to isolate this area from air movement. Then you can apply heat. You may want to make a temporary plywood barrier around this area so your heat stays confined, thereby using the minimal heat needed to keep the temp you want. The heater will most likely handle the job; you should get a thermometer and keep the space at 40 degrees farenheit or slightly higher. When the warm weather arrives, remember to open the air venting again.
Oct 11, 2009 | Patton Electric Patton PUH680-U Electric...
yes we had that problem a couple of times a couple of years ago and installing another unit cut it less than half.
Jun 22, 2009 | Lomanco PCVI POWER CRAWL SPACE VENT Fan
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Lomanco PCVI POWER CRAWL SPACE VENT Fan Logo
85 people viewed this question
Top Lomanco Dryers Experts
Marvin
Marvin
Are you a Lomanco Dryer Expert? Answer questions, earn points and help others
