Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
Power switch will not turn the camera on.
Camera is only a few months old. Can you purchase a new switch or what is the proper fix?
  • 6,784 Answers
HI, This type of repair will need to be initiated by the manufacture in this case. the actual repair parts needed are not available for consumer purchase.
The best Action here will be to contact the manufacture asap. the representative will issue you a repair ticket and, will direct you to the nearest repair depot in you state or area.
Posted on Jun 21, 2009
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Hello, I purchased a finepix s5700 about 18 months ago. It has worked perfectly until the last few weeks. I can turn the camera on if I hold the playback button and switch on the power, and can scroll...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 29, 2009 | Fuji FinePix S5700 Digital Camera
I just added a new security camera system in my home. When the power supply for the cameras is turned on, the remote control for my car only works within a few feet of the unit. My wireless keypad is also...
We believe the problem is not coming from the 12VDC power supply. Can you try the following and let me know the test result?
1. Unplug the power supply box
2. disconnect all the camera power wires from the power supply.
3. Turn on the Power supply "without any camera connect to it"
4. Check and see if your garage door opener work properly.
5. is the remote control built-in your car or it comes with the garage door opener?
email the result to info@cctvfactory.com and I will find a solution for you.
Thanks
Thomas
CCTVFACTORY.com
Oct 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Easyshare Z1285. Lens stayed out. Camera won't stay on. Tried 3 new sets of batteries. Camera only 14 months old.
hello, you just not discribe proper your problem,if your camera turns on and whithin seconds its offf with beep on lcd then you need to cheak lense assembly,just clean it properly and fix it carefully,ihope you find what you want
Aug 25, 2009 | Kodak EasyShare One Digital Camera
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
My kodak Easy share digital camera will not turn on
clean the connectors internally to which the battery connects.if they r dirty this can happen.or if that connectors get loose or little bit bent they cannot connect the battery properly and this happens.
Jan 07, 2009 | Kodak EasyShare C743 Digital Camera
Last year I bought my mom a digital camera for christmas. It worked great for about 2-3 months. Since then it is speratic, it will turn on let you take a couple of pictures then shuts down all by itsels....
Hi! Most digital cameras require outrageous amounts of power to work properly. Be sure to use only high quality, hi power ni-mh rechargeable batteries. Check for Sanyo Eneloop or Duracell. Sometimes we think the camera is broken, but in most cases is only insufficient amout of power. If you can't find the before mentioned batteries, look for 2500mA NI-MH type rechargeable batteries and a proper charger. Good luck!
Nov 22, 2008 | HP Cameras
Camera won't power up even after battery has been fully charges...
Hi
If you have the purchase information you should contact Canon directly and get them to repair it under warranty. That should be your first step. You can call Canon in the US here: 1-800-828-4040 Have your camera with you so you can give them the serial number.
One thing you can check easily yourself is the battery door. Is it closed properly? There is a small switch that is triggered when the door is closed, if this switch (beside the memory card slot) is not activated the camera will not turn on!
If that's not the problem then I would suspect the fuse has shorted out due to static shock or some other source.
Hope this helps! If I can help with anything else please let me know, we are a digital camera repair business!
Good luck from: Darntoothysam com
Thomas
Sep 23, 2008 | Canon PowerShot SD850 IS Digital Camera
Digital camera( fuji fine pix z10fd)
hi friends,i am from india,few months (6 months) back i have purchased the fujifilm s5700 camera, but unfortunately the one of the pencil battery got leaked inside it, now in the one of the battery comoartment, out of total four battery compartment, some greensih fluid i can see. now after putting the fully charged battery, i am not able to switch on teh cmaera, i am worried a lot, it is under warranty period, of 2 years, but i am bit concerned, as few o my friends are saying that battery problem can not be fixed by teh manufacturer even in the warranty period.
please solve my problem, weather battteryleak problem be solved, and if solved, can it be repaired by manufecurer free of cost during warranty period.....
Mar 31, 2008 | Fuji Cameras
Case problem
Six Months Old- Sent it back to retailer or direct to manufacturer- Check out the Tech Support for the correct procedure a new camera is due unless they can prove damage has occurred.
Jun 17, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
141 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
