Question about Acer Aspire 5610-4648 Notebook
Toshiba laptop touchpad not working properly
I have a toshiba laptop that is not even a year old, that i do use daily.yet recently the touchpad is not responding properly, its very hard to even move the mouse, and chooses when its going to work, also it jumps about the screen.
  • seth veloso May 11, 2010
    I used to have a toshiba a while ago that did the same thing. I never fixed it but closing and opening the lid would for some reason usually make the jumping around stop. Good luck
    Scholar:
  • 155 Answers
Boot Toshiba disk to your CD ram. If you are using Toshiba Satellite 2410 it will only work with CD marked with its own model or any model of it. Open CD drive and look for Toshiba touchpad driver and install this to your PC notebook.
Posted on Jun 21, 2009
On a Toshiba Laptop C70-A Series , lost my arrow and some keys dont work. How can I get my mouse back, so I can do a backup ?
Depending on your laptop settings start by doing a FULL shutdown. After rebooting hopefully the mouse (assume you mean a touchpad) will be restored; and maybe the keys not working. If unsuccessful connect a USB mouse and USB keyboard and check settings of the touchpad and also select the default language keyboard. If still unsuccessful try reinstalling touchpad drivers. Consider a possibility of some problem or damage to the keypad and/or touchpad if this all happened recently and the above doesn't correct.
Dec 11, 2014 | Toshiba SATELLITE PRO C70-A SERIES Laptop...
Toshiba Satellite L675d-s7040 touchpad scroll not working
The problem is the sensor pad, cracked ribbon wire, or the ribbon cable is not properly attached to the plug on the motherboard.
Apr 11, 2012 | Toshiba Satellite L675D-S7040...
Toshiba Laptop approx 3 years old. It fell out of
Please handle your PC with care. Since it fell abt 6 in., it must have some connection problem that will still be repeated as soon as it bangs. If it doesn't work in few days from now, check the HDD it may have caused damage because of the fall. Then if you can open any board, unplug connections from outlets then press soldered connections in the motherboard.
Just a pre-caution. But if it persist, see your supplier's technician.
Thanks
Dec 11, 2009 | Computers & Internet
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
May 27, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Toshiba TouchPad Not Working
tap on the touchpad or click on the top rightand if that does not work it is defently the hardware or software
Jun 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Acer Aspire 5610-4648 Notebook Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
