Question about Philips 32PW6006 32" TV
Trouble switching on
Takes several attempts to switch on ,keeps going to standby .and the right side of the screen is waving
  • steve1107 Jul 17, 2008
    mine takes a few attempts before it comes on and the brighter the picture the worse the right side starts curving in after a couple of minutes all is good
Same problem also!
Posted on Jan 04, 2008
Have 100% same issue - no solution yet - but engineer calling tomorrow
Posted on Dec 20, 2007
My Samsung tv model CS - 29M20MH switch onto standby mode with led flashing several times then switch off - no screen coming on
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jul 20, 2015 | Samsung Televison & Video
first ensure the right side is closed (Section that exposes the drum cartridge) and that the latches are not broken OK with machine on take a paper clip end stick in the tiny hole on the right side of the control panel (From then on you can only use that paper clip:):):) for this procedure (Copier Tech humor:)) The paper clip is going to touch a small switch which turns the to several screens if its say abort that is ok what you are looking for is going to be on left side of the screen in the middle a small purple dot when you see the dot press 3 that will activate trouble reset it will still code out with your c500 code but now go to utility mode see the new button Maintenance touch it you will see trouble reset touch that machine will go thru the entire cycle again you will see the small dot DO NOT touch let it go to "Ready to Copy" if not you have a problem with fusing unit the Hot part DO NOT CONTINUE TO RSET you can catch the machine on fire have a tech come out a look at it.
Jan 31, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
Minolta di251 co500
First ensure that the right side of the machine is closed there are two latches on the side door inside are either one broken? if not ensure the door is closed. Take a paper clip on the right side of the control panels a small hole touch the switch inside with the paper clip. (From then on only that paper clip can be use to this:):):)) The screen will state abort that OK, then the screen with three little copier comes on to the left on the control screen will be a small blue/purple dot when it shows hit 3. Then when you go to utility/counter screen there will me a maintenance mode touch it. touch TROUBLE RESET let machine do its thing code should go away. if it comes back there is a problem with the switch in front cover you can not see and the fusing unit the hot part and the side door not keeping the switch you can't see closed telling the copier to provide 117VAC wall outlet power to the fuser unit the hot part.
Oct 25, 2013 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
I am seeing the code H02 on the display panel when attempting to play a DVD. I have attempted to play several different DVD's. I have also switched the unit to standby mode then back on. I then...
This is what the manual says:
Trouble may have occurred. The number following "H" depends on the status of the unit.
Reset procedure:
Press [POWER ?/I] to switch the unit to the standby mode and then back to ON. Alternatively, press
[POWER ?/I] to switch the unit to the standby mode, disconnect the AC power supply cord, and then
reconnect it.
If the service numbers fail to clear, note the service number and contact a qualified service person.
I know these things you have tried so here is the contact information for customer service:
In the U.S.A., contact the Panasonic Customer Call Center at
1-800-211-7262, or e-mail, or the
website (
Mar 01, 2011 | Panasonic DVD-S35 DVD Player
Having trouble activing the wireless application
There should be a switch on the front of the laptop, on the edge. It should be a switch that is two-directional. There will be some pictures, one with a computer, and one with a computer with some waves coming out from it. Switch the switch to the side of the computer with the waves, and you will activate wireless internet. Follow the on-screen directions and you will receive the internet.
If this does not work, contact your internet supplier or find an internet supplier.
Jul 28, 2010 | Toshiba Satellite L500 Series Notebook
TV won't switch on
1. Your Tv is in need of service.
It sounds like the tube that give light to the screen for visual is defective and needs replacement.
2. The power supply circuit needs repair. Possibly a capacitor or diode has failed in the start up circuit
Mar 19, 2010 | Televison & Video
I switch on the phone and the nokia writing comes
IC is not working, just change it and your problem will be solved
Jan 30, 2010 | Nokia 5800 XpressMusic Smartphone
My laptop screen
Occasionally the toolbars just transfer themselfves to the side. If this is the problem, and say the toolbars are on the right side, just point near the lower part of the toolbar and then keep the left click mouse button down and drag it back to the bottom of the screen. May take several attempts.
Feb 17, 2008 | Computers & Internet
Philips 32PW6006 32" TV Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
