Question about Acer Aspire 9300 Notebook
Acer aspire 9300 black screen (display adapter)
I have an acer aspire 9300 and it has black screen, everytime i turn it on its makes 1 long beep and 2 short beeps i have looked at the beep codes and it indicates a display adapter problem is there anyway to fix this ?
  • x_reece_x Jun 21, 2009
    thank you for the advice but i just tried it around 5 times and still the 1 long and 2 short beeps :(
    Problem Solver:
When i turned on my acer aspire 9300 the computer is working but no display the screen is dark
Posted on Apr 22, 2011
    Scholar:
  • 155 Answers
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Posted on Jun 21, 2009
Acer aspire m3710 one long beeping
How many beeps?
Depending on the number of beep it might mean a defective video adapter display or bad memory.
Jun 29, 2014 | Acer Aspire M3710
My acer aspire one beeps when i switch on 1 long 2 short and wont power up
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk, and remains active until turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive SATA
Make sure they have a secure dust free connections.
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate.
Hope this helps.
Nov 27, 2012 | Acer Aspire 9300-3716 Notebook
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
My acer aspire 9300 have beep code: 1 long and 2 short in start up..
This beep code is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
This is most likely a video problem.
Try re-seating the RAM, the video RAM is shared, uses part of the main RAM.
Also try restoring the BIOS setting back to the default settings.
Mar 03, 2011 | Acer Aspire 9300 Notebook
No post in Acer aspire 9300 black screen, can hear fan, no beek codes Happen while I Swiched on PC and connected headphones. After 2 minutes I came t PC again and Vista was not responding, mouse not...
first, remove any external device as well as the ac adapter and the battery. while the ac adapter and battery is out, press and hold the power button for about 15seconds. then reconnect any power source and turn on the system. if it still doesnt turn on, remove memory, expansion cards, hard drive and optical drive then turn on the system. if it's still not turning on, the motherboard is faulty. but if it do turned on, reconnect the removed components one by one so you will determine which component is causing the issue. hope it'll help. good day. =)
Dec 03, 2009 | Acer Aspire 9300 Notebook
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Acer aspire 9300 screen doesn't show . it powers on but the screen is still black. its not two years old yet.
You got two year warranty on it? My acers have always had only 1 year warranty.
The laptop is most likely unable to start up. In most cases its a hardware issue, should take the laptop to a local professional for a check or if your in warranty contact acer.
Possible reasons could be bad memory, overheating, failed mainboard, failed video adapter, loose contact between display and mainboard.
You can try reseating the memory in the bottom of the laptop, it will be covered with 2 screws.
Remove them, and take out the ram from the computer, make sure they are clean, do not use water, or clean them, you can use the eraser end of a pencil to clean the contacts on the memory modules.
Place them back in and make sure they are in the right away, only handle them from the sides.
If the problem still remains, unplug and remove battery again, (might aswell keep the battery removed untill the issue is solved.)
Remove both ram modules from the laptop.
Start up the laptop with no ram at all, it may beep or complain, or it may do noting, unplug after 1 minute.
Plug in the other memory card, plug the machine to power, try starting up, if it works, turn it off and place in the other aswell, turn on and see if the machine works, if it does, problem solved. If it does not work.
Remove both ram modules, try the other memory on both slots and try starting up each time, remember to unplug power every time.
If the problem remains then do the same with the other memory module try it on both slots.
Next thing you could check at home is the cables between the display and the mainboard, you can also check the display in a dark room or under a light and see if there is picture on the display but no backlight, in that case the issue could be the cables between the mainboard and the inventer or the inventerboard or the backlight itself.
This will require repair in any case take it to a local professional.
Sep 11, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 Notebook Logo
2,999 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
