Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No spark mower started and i mowed like 5 swaths , then it started acting like it was running out of gas, (tank full). i changed out the old gas for new, installed new spark plug, still no spark
    New Friend:
    Problem Solver:
  • 14 Answers
Probably just a coil, common to fail, just make sure no mice have been under the cover chewing on the wires first,,, very common!!
Posted on Jul 12, 2013
  • 513 Answers
The magnet went bad or the fuse popped on the mower check fuse & let me know wade at wadembly@aol.com
Posted on Jun 28, 2009
Mower stops running after I've been mowing for about 30 minutes changed the spark plug, fuel filter.was mowing then it just started acting like it was running out of gas until eventually stops.
Take the fuel bowl off and clean then clean the fuel jet. a partial plugged jet will do this. could also be the float in the carb is sticking shut so could need cleaning as well. Would do good to run fuel cleaner through a tank of gas to clean things up. This is just an idea but worked for me.
Sep 15, 2015 | Garden
Why wont my John Deere D130 will not stay running
You know the old adage, Keep it simple, lol.
I was mowing along on my LA145, which had about 200 hours on it, and it slowed down then died. Before it died, it was acting like it was losing power. It felt like it was only firing on one cylinder. I waited a bit and it restarted after a lot of cranking. I made a couple mowing passes, and then the same thing happened.
Because I have mowed commercially for many years, I know my equipment inside and out. This mower was in top running condition and should not have been acting this way. There were no engine misses, no backfires and it was not normally hard to start. I knew the carburetor was clean, the coils were good, and the plugs were new. The fuel filter was recently changed. I got off, lifted the hood and gave a general inspection of the engine compartment. I noticed the fuel filter was nearly empty. I pulled the hose off the tank side of the filter and saw there was no flow.
The gas should gravity flow from the tank to the filter, if the tank has a good supply of fuel. Not that I recommend this practice, but I have no problem with doing it myself....I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (it required several lungs full of air, you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
The problem repeated itself several times last summer. Back at the shop, I used compressed air to blow the line clear. The problem has not shown up in quite some time.
Aug 29, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Why is my riding lawn mower acting like its running out of gas?
probably needs carb rebuilt and needle and seat put in
Aug 25, 2014 | Garden
Lawn mower will not start after running out of gas.
are you getting spark?was the gas you put in newer than 30 days old?
Jul 22, 2012 | Poulan Garden
The last time I used the mower, it was running fine then cut off while I was mowing. I haven't been able to get it restarted. I changed the spark plug, filled the gas tank and added oil. It still will not...
Maybe the ignition module is gone bad. It helps fire the spark plug to make the motor to run. Also if it has a stop cable on it make sure the cable pulls back far enough to pull the flywheel brake off the flywheel.
If your mower was running then quit, it sounds like the ignition module bad.
Sep 27, 2009 | Craftsman Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
207 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
