Question about Acer Aspire 3680 Laptop
Clean off and restor
Computer locked up stuck in safe mode
  • jaz101 Feb 23, 2008
    when im on my computer the pictures are like black and blurred everything else is fine except the pictures the words are fine some one told me my computer is in safe mode i dont know how to get it out
    Genius:
  • 1,601 Answers
If you want to shut it down. press and hold the power button.
Posted on Nov 03, 2007
When I turn on my computer it takes me to a gray screen declaring a failure to update windows successfully and just restarts repeats and routinly has become stuck in firsts level of computer hell.
Hi Leonard Fazio,
Have you tried going into Safe mode and the settings, control , uninstall programs - select show updates and then remove last update.
http://www.7tutorials.com/5-ways-boot-safe-mode-windows-8-windows-81
http://pcsupport.about.com/od/fixtheproblem/ss/safe-mode-windows-7.htm
another way is to select system restore while in safe mode and restore to an earlier version depends on what o/s you have. Search for it in control panel or settings. While in Safe mode.
http://windows.microsoft.com/en-au/windows7/products/features/system-restore
http://windows.microsoft.com/en-AU/windows-8/restore-refresh-reset-pc
Jul 25, 2015 | Computers & Internet
Mode safe start windows
In this case it would be best to perform a system restore.
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps. Thanks
Oct 27, 2013 | Computers & Internet
Computer stuck pre boot screen
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe with networking and hit enter. Once you are inside safe mode, then do a system restore.
David
May 22, 2013 | Computers & Internet
Vaio stuck on vaio screen
Try booting to safe mode. Restart your computer or turn it off and turn it back on. While it's starting, tap F8 until you see the options to boot to safe mode. If you see that screen, then use the arrow keys to highlight safe mode and press enter. If it goes in, then do a system restore by going to START > Programs > Accessories > System Tools > System Restore.
Restore it to a known good date (the date when the issue was still not there).
If you cannot access safe mode, then you have a more serious problem. There are two possible reasons of that certain issue> 1. Operating System Failure which is easy to fix. 2. Hardware issue which needs the expertise of a technician. If you can't get into safe mode, then I suggest that you get the services of a technician.
I hope this helps!
David
Feb 08, 2013 | Sony Vaio Vgn-C140 Vgn-C190 Vgn-C290...
My ingnition won't tunn and stearing wheel won't lock
When the key does not turn it means the tumblers inside the lock cylinder are stuck or jammed. Use penetrating fluid and spray it into the lock and insert the key numerous times. Also hitting the end of the key while it is in the cylinder will help to get the tumblers free. Use a rubber hammer for this.
Dec 24, 2010 | 2005 Dodge Grand Caravan
I was doing an automatic update and had to restart my computer... since then it has been stuck on the wecome screen saying "please wait" for 2 days now I have taken out the battery and restarted it several...
when you restart it , just press f8 so you will be taken to a screen where the first option will be safe mode, select it and it will hopefully log you in. Once you are logged in safe mode, anything you wanna do, and then shut down the computer. Start it again and this time let it boot normally. Hope this way will work
Sep 14, 2010 | Computers & Internet
Laptop is stuck in safe mode Acer
I faced the same problem with my laptop. I tried several methods. But none of them worked. But finally when I tied the following procedure it worked.
The following instructions work on a computer running Windows XPmag-glass_10x10.gif only, this is assuming that your laptop has XP installed on it. Use this only if your computer wont come out of safe mode by restarting it.
Go to Start > Run and type "msconfig" in the dialog box that comes up. Press Enter or OK and the System Configuration Utility box should come up. Click on the "BOOT.INI" tab. Down in the bottom left corner of the window under where it says Boot Options there will be several checkboxes. Make sure that the /SAFEBOOT box DOES NOT have a check in the box. When it is unchecked restart your computer and you should be out of safe mode.
Dec 28, 2009 | Acer Aspire 5315 Notebook
Can't restore my hp laptop its window xp pro to feburary its stuck on june hw cn i make it go to feburary i have try it on safe mode no luck . my reason to restore it because my computer is runing slow and...
Try downloading RegScrubXP, this is a very good program.
It cleans up your registry and can bring slow computer up to speed again.
I find it safe t use and have been using it for years now.
Jun 06, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Computer gets Stuck in Startup
Try tapping 'F8' as the computer powers up.
This should bring up the advanced options menu.
Highlight 'Safe Mode with Networking' +enter
Let the PC boot into safe mode
Then click
'start'>>programs>>accessories>>system tools>>system restore....
Pick a restore point before the problem started and let system restore run its course and reboot the pc.
Mar 14, 2009 | HP Pavilion F50 17" Flat Panel LCD Monitor
Computer keeps rebooting into safe mode
Try going to system tools, and select system restore .. If that does not work ,May be virus, may have full restore with formating the hard drive
Mar 26, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
