Simmons Outdoor CaptureView VGA Binocular Logo
A
Anonymous Posted on Apr 30, 2014
KODAK CAMERA WILL NOT TURN ON
Kodakdidgal camera will not turn on have tries sereral new batteries and nothing
My Kodak C190 will not power up. I have new recharged batteries and get nothing when I try to turn it on.
If sure that the batteries are good and that you have good clean contacts, then the camera has gone to camera heaven and it is time to go shopping since repair on those units is not cost effective.
2answers
Kodak Z740 digital camera
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Lense stuck out - camera powers on only briefly then stops - hear one "bing". Tried removing battery - does nothing with cable power only.
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
2helpful
Cannot turn camera on. Lens will not extend outward camera
Sounds like a No power issue: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Camera will not turn on,tried new batteries still nothing.camera is kodak c813
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
- oxy-alkaline digital camera batteries AA
- Ni-MH rechargeable digital camera batteries AA
- alkaline batteries AA
- lithium batteries AA
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the dial mode.]
7. Turn on the camera
if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
2helpful
2answers
I have a Kodak Easyshare C180 digital camera. I open ity, take a picture and then it closes. I then cannot get it open again. I see the on/off button but nothing happens
Is the camera LENs won't retract? Try to use a brand new different recomended batteries like alkaline batteries or lithium batteries. If your using a rechargable batteries make sure that they are fully charge. You can also try to turn the camera ON without using memory card. Remove the memory card on the camera. Then put a new recomended battery, try to turn it ON if the camera will not turn ON or stay ON call kodak support line. Support in English and Spanish is available at 1-800-235-6325 (23KODAK)
2helpful
Camera lens does not retract
Here are the steps:
1. Make sure you will install a new or fully charged
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
HELP ~~~~~Camera wont turn on
You didn't provide a make or model for the camera, but if it's a Kodak, fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 28, 2009 • Cameras
Kodak easyshare Z740
I hope that helps.
Top Simmons Outdoor Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
