Question about MSI KT4V (MS-6712) Motherboard
Výmena procesora ?
V mojom po?íta?i bol procesor AMD Athlon XP2000+ AXDA 2000DUT3C.Ked?¾e sa mi zdal pomalý vymenili mi ho za AMD Sempron-Thoron, frekvencia 1600MHz, reálna 12000,2MHz. Základná doska je KT4-V (MS-6712 v1.X) ATX Mainboard.Ked?¾e sa mi zdá ?¾e je po?íta? pomalý, procesor ide stále na 100% napríklad pri nahrávaní cez linkový vstup programom Ashampoo Studio 3, v podstate sa nedá ani z programu odstavi?¥ ke? chcem.Dlho spracúva inštrukciu. Najlepšie je potom ukon?i?¥ CTrl+alt+del.Niekedy ke? s?¥ahuje antivír (update) odstaví po?íta? - spadne.Preto by som chcel ak to pomô?¾e vymeni?¥ procesor, za ?o najvhodnejší a pre dosku najrýchlejší. ?Žakujem vám za informácie.
Where can I get a sr1030nx AMD procesor. On the side has a no. 27493. Assembled in Malaysia
It's an AMD XP 3000+ made in a socket A configuration. It's an extremely old model, the only source for another one are sites that sell second-hand parts, like Ebay.
http://www.ebay.com/sch/Computer-Components-/3667/i.html?CPU%2520Type=Athlon%2520XP&Computer%2520Type=Desktop&CPU%2520Socket%2520Type=Socket%2520A&_nkw=amd%20xp&_catref=1&_dmpt=CPUs&_fln=1&_ssov=1&_trksid=p3286.c0.m1539&Clock%2520Speed=2%252E2%2520GHz%7C2%252E6%2520GHz%7C3%252E2%2520GHz%7C2%252E73%2520GHz
Sep 22, 2011 | AMD Compaq Presario SR1030NX Athlon...
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Overclock procesor athlon 64 2800 +?
There are a bunch of guides out there to help you with the overclocking process.But bear in mind that you will loose your warranty as son as you change the frequency cycles. Also make sure that your system can withstand the excessive heat that will be generated by the processor.You should arrange some alternative cooling system like liquid coolers,Highgraded thermal insulation pastes or atleast a couple of additional coolant fans. Go through this.... http://www.hardwaresecrets.com/article/102
Nov 03, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
Restore display on KX-A115CE
KLAVESNICA IDE VYTUKAVAT CISLA LEN NA DISPLEJI NIC NEVIDNO!
OMYLOM SOM VYPOL TELEFON A KED SA HO ZAPOL TA OSTAL DISPEJ NEFUNKCNY AJ NOVE BATERIE SOM DAL .
Aug 27, 2008 | Lands Phones
Can I use Athlon X2 procesor with this mother board?
It takes Socket-939 processors (AMD Athlon 64/Athlon 64 FX [K8]).
X2 processor used Socket-AM2
Nov 11, 2007 | PC Chips A21G Motherboard
MSI KT4V (MS-6712) Motherboard Logo
66 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
