Question about Nokia 3100
No signal for N3100
Same problem from the thread
    New Friend:
  • 70 Answers
There is some technical problem please repair it.
Posted on Jun 21, 2009
Janome TS100Q sewing machine. Lo signal comes on and thread tangles on bottom side of fabric
Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
This is a discussion of the Lo error code:
https://sewing.patternreview.com/SewingDiscussions/topic/90569
Feb 19, 2018 | Janome Sewing Machines
I have a Elna excellence 7600. Why does thread keep breaking while chain stitching fabric?
Thread breaks
first check to see if there is an actual thread break, then check the threading-both needle and thread
Sometimes the machine will signal a thread break when there really isn't one, at least not technically. For example, a mis-threading can cause the thread break sensor to think there is a problem because it is not sensing the proper thread tension. This can also happen if a loop of thread forms suddenly resulting in slack in the thread.
a thread break signal are really a "thread out" indication most often triggered by an empty or low bobbin or the needle becoming unthreaded.
rethread the machine and correct any low thread conditions.
Actual Thread Breaks
Examine the thread break. Is it a clean snap or is it shredded?
Next, examine the thread path. Did the thread get caught on something
A common problem with embroidery thread is that due to its slippery nature, it can slide down the spool and get hung up underneath causing a sudden jerk on the thread. Rayons will probably just snap at this point but some poly threads may be strong enough to resist breaking and instead flex the needle resulting in a broken needle.
Metallic threads often cause more breaks and shredding because they tend to form loops and kinks as they come off the spool. This is exacerbated by small spools with narrow diameters and short thread paths from the spool to the first thread guide. A simple solution for this is to extend the thread path.
Thread Factors
Lets look a little closer at thread. Embroidery threads are more fragile than those used for garment construction or quilting. Start with quality thread and know how to care for it.
Embroidery threads can dry out when exposed to light, heat, drafts, and air conditioning. They can become "bruised" if dropped or handled roughly. As they age, they become more fragile. Due to dying and other processes, certain colors break more easily than others. Check this for yourself. Try breaking a white thread and then a black. Also notice that the black is slightly thicker than the white.
Rayon tends to break easier than poly. Metallics are more temperamental and finicky
Needle-Related Possibilities
On a single needle machine, if you are getting continuous thread breaks with multiple colors and you are sure you can eliminate the thread, then look at the needle.
Is it the right size? For 40 wt rayon or polyester thread, a 70/10 or 75/11 works well on most fabrics.
Embroidery needles have a slightly larger eye to reduce friction on the thread. High quality needles have a well-polished eye that won't snag, abrade, or shred the thread. The thread can pass through the eye of the needle 50 to 60 times before it is laid down on the fabric. Any rough spot on the needle or thread path can literally saw the thread in half
The broken needle is the least of your problem! If your machine doesn't stop the instant the needle breaks, it may severely damage your fabric. Needle breaks can cause scratches and rough spots on the throat plate and in the hook area that can shred thread. Until these problems are smoothed out, thread breaks will be your reality.
It is possible for the fabric and/or stabilizer to the source of thread problems. For example, heavy, stiff fabrics can easily strip some metallic threads
If the lower thread keeps breaking, open out the bobbin hatch and check that there is no lint buildup that is hindering the smooth flow of the thread. If there is any lint, remove the bobbin and clean the area thoroughly with a brush. Also check that the bobbin is wound correctly and that the tension of bobbin thread is even. Poor maintenance and incorrectly wound bobbins are the culprit more often..
Mar 22, 2016 | Sewing Machines
How do I tighten the turn signal arm on 1977 Buick limited. It works however loose in the up and down position.
I am pretty sure the screw or bolt has come loose lever to signal switch. Steering wheel etc. will have to be removed to access loose
fastener
link below is not your car, but shows the basics of what has to be done to access switch.
press the helpful button.
Turn Signal Cancelling Cam Replacement
Jan 22, 2016 | Buick Cars & Trucks
Went to install sissy bar on 2004 Harley-Davidson 883 custom and the bolt threaded out of turn signal and won't go back in. How do I fix this. Problem happened with both sides.
Hi Kevar129, this issue should be repaired by an experienced professional at your local dealer or reputable shop. It can be done without removing the cylinder head, transmission or primary depending on your scenario. Your damaged threads can either be restored or replaced with steel threads without contaminating the affected area with broken aluminum threads. good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 17, 2011 | Harley Davidson XL 883C Sportster Custom...
I am not able to connect and attach my BH101 nokia bluetooth device with my new laptop which has Windows 7, Model no. is Toshiba Satellite M-300 and earlier i was using Lenovo N3100 and that has Windows XP...
You said NEW computer with Win 7? That is hardly new, unless you mean the computer is NEW to YOU. Obviously Win 10 is far better, with current drivers and better security. Nevertheless, older operating systems need Updated Drivers for current hardware. Go to the Device Drivers and review all hardware listed. Open each one individually and Update Drivers. When finished, you should have current driver function and all devices should operate very well. I still think you should up date to Win 10.
Feb 06, 2018 | Computers & Internet
The bobbin case sounds loose and the thread jams with the fabric and everything gets stuck.
That use to concern me too! I thought it signalled a problem, but my bobbin case has always been loose and that was not what was causing my thread and fabric jam. Usually what causes the jam is an incorrectly wound bobbin, wrong needle or old needle, old thread, or a slightly warped bobbin that is hard to see/detect. Change everything out--needle, thread, bobbin...this usually does the trick!
Mar 24, 2010 | Husqvarna Rose
My own number from my old sim doesnt appear
ring a friends phone and you'll get it that way but make sure you have your phone set to show your number
Dec 17, 2008 | Nokia 3100
Nokia 3100 Logo
129 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
