19 seer infiniti system, system will run for 2 mins. and then cut off and it will not show a code to the outside unit board or the thermostat. Replaced the thermostat and the outside low voltage wiring, then went to test mode on thermostat. Turned high cooling for 15 mins, it will run for 10 mins and then cuts off. It still does not show a code. If you go to the thermostat and turn it off, and reset it to cooling it will run for 2 mins and will cut off.
  • 2 more comments
  • kris1274 Jun 21, 2009
    Are you saying the outside control board?
    yes, power supply has been checked, it has 230 volts, constantly. I checked on c and d terminal it had 24 volts continous a and b is communicating.
    the wiring has already been replaced, do you recommend using what shielded wire
    Top Expert:
  • Heating & Co... Master
  • 81,400 Answers
This cut off is very likely being caused by a defective compressor module thermo limiter (prevents overheating the compressor), replace it.
Posted on Jun 22, 2009
  • 470 Answers
Did you check the power supply?? it maybe the cause of the problem?
Posted on Jun 21, 2009
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jun 21, 2009
    before i go to my first remedy of that problem, may i insert the initial solution,, pls check the wiring connection if it is perfectly fit with the voltage needed, i think there's a grounded on it. check it carefully
    Brigadier General:
  • 3,614 Answers
have you check the relay switch on your a/c, a possible relay switch resulting this problem..
Hope this initial info helps
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
We have a Haier 13 seer central a/c unit #HC18-60d1var which will not turn on when running a/c. What can the problem be? The unit is only about 2 years old. Thank you in advance for your help.
I'm assuming that you mean the outside unit won't come on? Typically a thermostat wire is damaged outside stopping the 24 volts needed to energize the contactor coil. Often times the breaker is tripped to the outside unit as well. Take the panel off the outside unit and push the plunger in on the contactor with a screwdriver. If it comes on then it is definitely a 24v problem.
Oct 24, 2013 | Haier Heating & Cooling
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Have new infinity 19 seer heatpump
You will like void any warranty call the co. that installed it but I wouldn't tell them you have been playing with it It sound like it has control issues but you knew that hard to tell with out putting my eyes on it ya never said which code. Tom
Jun 21, 2009 | Carrier 38CKC036 Air Conditioner
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
I have a Carrier infinity model 38tdb037-3. The outside unit will not come on. the control board on the outside unit shows an amber led on status 2.it is a steady constant flash.the error is an apparent...
Have you eliminated the possibility of a high or low pressure error. Sounds to me like it's off on safety. Should have troubleshooting the flash right on the panel. Test your pressure switches for continuity.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 13, 2017 | Carrier Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
