No power at all!! pls help!!
I have a ViewSonic VX715 17" LCD Monitor and it has no power at all. no display, no lights etc.... wat could it be the prob... pls help.... pls pls pls pls..
Change C922, it's probably inflated and leaky
Posted on Dec 17, 2007
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
Its not showing anything but it has power
please check whether the VGA cable is properly connected to your monitor and CPU and check. it should work. if not try with another cable.VGA cable and Pin will be blue in colour
Feb 13, 2011 | ViewSonic VA703B LCD Monitor
I have this monitor - ViewSonic VA712 and when i use it, turn the PC on, the monitor power status light turns green, then display turns absolutely black (still the power status is on GREEN). Can hear from...
Very common problem with Viewsonic and all other brands of failed moniotrs is due to bad caps as you can see here:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find for further help.
Sep 04, 2010 | ViewSonic VA712 17" LCD Monitor
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
The monitor will not display or power up. I've
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 19, 2009 | ViewSonic VA703B LCD Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
No power to monitor despite being plugged in
Check your video card. Is your computer booting up?
May 25, 2008 | ViewSonic VX910 19" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Viewsonic vx 910
it is power problem pls show it service personnel
Sep 21, 2007 | ViewSonic VX910 19" LCD Monitor
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
