Question about Dryers
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
I have the matching Frigidaire Gallery washer/dryer that can stack, purchased in 1998. It has been in two locations, both stacked and unstacked, and once with a new, very short dryer vent. It has never dried the load on the first 60 minutes cycle, no matter what option I choose. I always have to dry it another 30-60 minutes. This is for full or semi-full loads, and since the units match, I figured the dryer should be able to handle whatever the washer can. It heats and seems to run properly, but it just doesn't do it in a single cycle, which is frustrating and time consuming. Any thoughts?
  • Susan Franklin
    Susan Franklin Jun 21, 2009
    Sorry, but I explained that the unit had been moved to a new location with a new, very short vent. It was properly installed, with the problem I describe in mind. It had nothing to do with ventilation, because the problem continued.
    Problem Solver:
  • 18 Answers
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Posted on Jun 21, 2009
  • mw repairs Jun 21, 2009
    A dryer dries clothes by 3 methods. The amount of heat, good air flow, and the ability of the clothes to tumble properly(freely). You are right in that the dryer should be able to handle the same load you put in the washer and since you also stated that it has good air flow to the outside then lets examine the heat. Heat depends on the amount of electricity. If the dryer operates on 240v then 60mins should be sufficient but if it is 120v then the amount of heat produces may not be enough. Lets suppose that the dryer is getting sufficient voltage, the problem then might be burnt wiring (usually at the element). or even a broken element. Sometimes an elements coils maybe broken but is touching the housing and still producing a small amount of heat, I would suggest calling in a tech to investigate the problem further.
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I want to change the door around to match the
Unfortunately, only some model Dryer doors are able to be changed, not the washer doors. You can find out the Model of your dryer and I can let you know if indeed you dryer door swing can be changed or not. The other solution is to stack the set to not have the doors impede loading and unloading if your models have a stacking kit available for them. I hope this helps! Good luck!
Dec 29, 2009 | Frigidaire GLTR1670A Front Load Washer
Hello, my frigidaire dryer-washer is not drying...it could be running for several hours but it doesn't dry
if the clothes are not getting warm at all, heater element needs to be replaced. if they are getting warm, you need to check filter, exhaust tube and out side outlet for blockage
Sep 04, 2009 | Frigidaire FEX831CS Top Load Stacked...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLEH1642DS1
Check the door switch on the dryer to make sure the leads are all on.Check your thermal fuse .Its likely that its one or the other.
May 20, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Dryers Logo
213 people viewed this question
Top Dryers Experts
Marvin
Marvin
