Question about Hard Drives
Delete data from drive K on Seagate Free Agent PRO
How do I manually delete data on Seagate Free Agent Pro. It scans my system, but only partially. I think if I can delete the data, uninstall the program and then re-install the program, that might work.
  • 4 Answers
Re: Delete data from drive K on Seagate Free Agent PRO
Hi there! In order to solve your problem, just go to System Restore and restore your computer the date during you installed the Free Agent Pro, then try to re-install the application after the system restoration.
Posted on Nov 03, 2007
0 characters
3 Points
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Free Agent Pro Out Of Space
format backup drive and repartition to a single partition. do not backup programs unless you have clone disk.
Jun 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate Free Agent Drive Cannot be Modified on Mac G5
First of all Hello John :)
The new seagate drive you got needs to be unpartitioned and its file format system needs to be deleted and changed.
NB: You will lose all your data so make sure that you copy everything useful off it before you do these steps.
1. Get hold of a windows PC and right click on my computer
2. Choose manage ... choose disk management right click on the drive and delete the partition type
3. delete again until it comes unpartitioned space
4. Then go to your mac and you should be able to format it as a regular Mac drive.
5. If the Windows PC is inaccessible. Get hold of a copy of Linux UBUNTU distro. Boot your MAC from CD choose to boot os from CD (don't worry it will install nothring on your MAC it will just use the CD but make sure you choose the right option)
6. Keep your hard drive attached so it gets detected during bootup. Once the UBUNTU OS boots choose GParted and from there do the same thing i explained above.
Hope that this was of help :)
(please take some time to rate solution)
Jan 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Data Storage
Make sure you are storing them in both places. I have a hunch that even though you are storing them in the my documents folder it is the one on the external drive that is storing them & when you are trying to delete the computer is reading them as stored to the external & is deleting from there. Hope this helps & please remember to rate my answer. Thanks.
Dec 31, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drives Logo
257 people viewed this question
Top Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Hard Drive Expert? Answer questions, earn points and help others
