Question about GE WBSE2090A Top Load Washer
My maytag top loader washer won't spin but agitates,what is the problem
    Problem Solver:
  • 18 Answers
Maybe a sock stuck between the two tubs. If it has not dropped down too far you maybe able to feel it. Open the lid and pass your fingers gently between the two plastic tub covers. The lower cover moves with the inner tub while the upper stays still.
Posted on Jun 21, 2009
I checked the coupling and it looked fine. Should I take the basket apart and make sure there isn't something in there that is causing the washer to not spin, It seems fine during the wash cycle. some say it might be the timer.
Posted on Jul 10, 2009
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
  • 117 Answers
SOURCE: washer get water, no spin . it does fill wash
Tilt the machine back and check to make sure the belt underneath did not fall off. Best of luck Arturo!
Posted on Feb 25, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
May 17, 2009 | Washing Machines
May 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag washer
lean the washer back .......
Oct 07, 2007 | Maytag MAV7600 Top Load Washer
Sep 27, 2007 | Washing Machines
GE WBSE2090A Top Load Washer Logo
879 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
