Question about Ziff Davis DAVIS Multimedia S8 Multimedia Projector
Broken mirror-davis dl s8 projector
Mirror broken at the back of the round glass magnfier thing. (the bit where the light shines from the lamp thru the round magnifier thing. How can this be fixed. Also where can i download the manual for the projector. Thanks.
4 Suggested Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
marsrover
  • 682 Answers
SOURCE: toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Posted on Mar 21, 2008
  • 12 Answers
SOURCE: Davis Cincevision projector help!!!
wholesale and retail all brand projectors and its accessories
Posted on August 25, 2011 by maggie258240135
I am Maggie from Yue Yu Electronic and I am in charge of the export business. Considering we are wholesale and retail all brand projectors and its accessories(lamps, ballasts, DMD Chips, LCD panels, color wheels, remote controls, polarizers, light tunnels, filters, burners, main boards, lens, etc.), we will provide customers with high-quality, low-cost products and better services. We have exported projector parts for many years, and sincerely hope that we could establish a long term and best cooperation with you.
If you have a need, please contact us, including your satisfaction! Hope you have a good business year!
Yours Faithfully
Maggie
Yue Yu Electronics
Mobile: 86-0-15302294942
Address: A1501,1508,NO.592Buynow Building, Tianhe Road , Guangzhou China
Web: www.yylamp.com
MSN: maggie258240135
Mail: Maggie2010great@yahoo.cn
Skype: maggie258240135
QQ: 258240135
Posted on Aug 25, 2011
Just replace my lamp with a new one, when i start my projector, everything seems to work fine but the lamp doesn't light up. the lamp light flashes green for 30 second, theres a ''motor'' sound in the same...
HI,
You can visibly inspect the lamp to make sure the bulb behind the glass is intact & the round part of the bulb is clear & round. Otherwise if possible return the lamp for exchange. If the same thing happens then the lamp ballast is likely bad. I have many in stock I can diagnose it.
Apr 14, 2011 | Sharp XR-10X Multimedia Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Red blinking light at bottom of panel indicating lamp replacement
The glass area you see can be cleaned, but I would use ONLY plain water and your soft cloth to clean it
Dec 27, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Lamp life
it usually runs on luminance hour by the thousand, by indicator the light becomes dim a bit and gradually loosing the brightness, to the extend it will no longer lit.
usually 5 thousand hour
Aug 06, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
My projector Benq pb6200 needs cleaning from the inside how???
I have an Optoma EzPro 737 DLP projector that accumulated dust inside the lens and for ages I couldn't figure out how to get rid of it. It cast shadows onto the picture and scattered light outside the edges of the picture. I thought I'd have to dismantle the whole lens assembly (then realised that this is virtually impossible without being an expert). I then stumbled upon a little black rubbery plastic panel on the side of the light path, which unclips. I then realised that the dust had built up on the lens that sits in front of the DMD chip (the thing that makes the picture).
Here's what I did, with the case open and having vaccuumed out all the dusty parts of the projector to avoid making the situation worse:
- Took off the little rubbery panel,
- Removed the lamp from the projector and placed a flashlight inside, shining into the light path (or a mirror directing light from a table lamp above)
- Looking directly into the lens from close up, you should be able to see the particles of dust stuck to the inner lens (with a nice magnified view)
- First tried blowing air into the gap on the side of the light path (I used a balloon pump).
- Next, I poked a piece of thick nylon fishing line into the hole so that it could touch the surface of the inner lens.
- While looking into the lens, I could see the tip of the nylon, then directed it to the largest dust particles and used it to scrape them off (nylon is much softer than glass, so won't scratch the lens).
- This was quite time consuming but I got rid of the most obvious bits.
I'm not sure how different this would be for another model of projector - but I hope it helps!
Dec 16, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Ziff Davis DAVIS Multimedia S8 Multimedia Projector Logo
169 people viewed this question
Top Ziff Davis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Ziff Davis Office Equipment and Supply Expert? Answer questions, earn points and help others
