Question about Magellan Maestro 4040 GPS Receiver
Does not charge
While in use, the message appears that Battery level is critically low and it it powering itself off. Even though I attempted to charge it in an outlet and I leave it charging in the car while in use, always. It's become basically useless
  • jeaniei Jun 21, 2009
    Thanks.....No I've never soldered. I might actually have a 2 year warranty that isn't up just yet so it might be covered. I hope so! Thanks tho for your answer. I appreicate at least knowing what's up
    President:
  • 1,111 Answers
The power port is broken...very common on that magellan and others..i have the ports if you are capable of resoldering it yourself..
Posted on Jun 21, 2009
  • Ben Dover Jun 21, 2009
    ok np...if they wont cover it and you need help, just let me know
Straight talk samsung galaxy proclaim cell phone. Turns off and on by itself. Will say battery critically low but when plug in battery shows not that low. cant do browser or apps unless plugged to charger....
Its battery is weak. Even though it shows full; when the O/S loads, the CPU of the phone will take large amount of current, and the battery is unable to supply it during that time. In short; the current storing capacity; at least 1.2AMPs, should be there with the battery, but now there is not. It won't hold charge; in terms of current.
Replace the battery with new one. There is no other problem to your phone.
Gopakumar Gopalan Google
Aug 07, 2014 | Cell Phones
Emachines charging
I've gone through exactly what your're going through right now.
I'm sorry to say but your battery is dead, you need to get it replaced. It can be replaced under warranty, if you have it.
To avoid this kind of a problem in future take care that you:
1. Don't let the battery drain out after your PC warns about low battery.
2. Try to maintain it's charge when you are not using it for days. The self discharge of the battery may take it below the critical level even when you're not using it. So keep charging it even when you're not using it.
3. Preferably use your laptop on external power supply (keep it on charging while using it whenever possible), charging it even when the battery is full doesn't hurt.
4. Let it have a charging and discharging cycle at least once in two weeks.
The above steps will help you maintain a good health of your battery and avoid the problem you're in currently.
Aug 31, 2013 | Computers & Internet
I have cannon digital camera IXUS 255 HS. I
Dear Tejas Belani,
I hope you're still reading this but I had exactly the same problem with the Ixus 255 HS as you describe (full battery - false message - filled battery icon when looking to pictures on the memory card).
After some failed rescue attempts (recharging, completely discharging, 10 second hold of on/off button), I think I finally found it: put a small piece of paper or carton in between the battery opening door and the battery. This pushes the battery a couple of millimeters deeper in the battery bay and ensures a good contact between battery and pins at the other end.
Seems like Canon were a bit cheap on the plastic levers that secure the battery ... or perhaps they erode after some time of usage. This type of camera is often exposed to more aggressive conditions than the bigger, more expensive camera's out there :)
Aug 20, 2013 | Canon Cameras
Phone will not switch on even though it is fully charged
Hello Dear Friend:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 29, 2013 | HTC Cell Phones
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Nokia 6300 wont turn on
5.Wait 10 seconds.
Step
Thanks
Apr 29, 2017 | Nokia 6300 Cellular Phone
Pc is telling me to plud it in when the battery is at 90%
Your power settings may be set up to inform you at 90% the battery is getting low.
Windows XP
Go to control panel, Performance and Maintaince(only in catigory view), Power Settings click Alarms tab and adjust the sliders to the desired.
Windows Vista
Go to control panel, click change battery settings, find the option selected click the link below it saying Change Plan Settings, click the link change advanced power settings, go to the battery section and adjust the low battery level and critical level.
Dec 07, 2008 | Acer Aspire 3680 Laptop
Phone will not take charge
I have the same problem with my phone i really don't know what is going on~!!!
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Power up problem
Your laptop needs a new battery. Buy a new one and have it replaced by a service technician for free.
Sep 15, 2007 | Computers & Internet
Magellan Maestro 4040 GPS Receiver Logo
144 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
