Question about Carrier 38CKC036 Air Conditioner
Have new infinity 19 seer heatpump
Outside you will run for about two min and not show a code on the board,then i change the low voltage wire and replace the thermostat and set back up and the thermostat does show a code, but if turn it off and back on run again for about two min. then too test mode for 15 min it will run for 10 min on high stage and stop
    Sergeant:
  • 340 Answers
You will like void any warranty call the co. that installed it but I wouldn't tell them you have been playing with it It sound like it has control issues but you knew that hard to tell with out putting my eyes on it ya never said which code. Tom
Posted on Jun 22, 2009
We replaced fan motor on heil heat pump , now the defrost isn't kicking in, is this a wiring problem or unrelated to us replacing the fan motor?
Check low voltage at heatpump need 24voltsat R and C tterminal s if you have 24 volts on defrost board change board .if you dont have 24volts from r and c you have to go to indoor unit and look at low voltage wireing . Check wire nuts or when replace ing motor might have knock some loose check all low voltage. Hope this helps
Feb 27, 2015 | Heating & Cooling
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Where is the capacitor located on a coleman heatpump
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
May 04, 2010 | Coleman Heating & Cooling
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
How does a 95% goodman gas furnace wire up with all fuel board & goodman heatpump 13.0 seer low voltage wiring
A picture is worth a thousand words. Check out this link for the best explanation.
http://www.alpinehomeair.com/related/diagrams_10.pdf
Sep 26, 2009 | Goodman GMS90703BXA Heater
Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Sep 20, 2009 | Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Outside fan runs all the time
Fan wired wrong to contactor. defrost board bad if it is a heatpump. outside fan relay is on board. Rusty
May 30, 2009 | Heating & Cooling
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
100 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
