Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
I HAVE A FRIGIDAIRE MODEL FEB386WECH, THE PANEL SHOWS AN F1 CODE AND BEEPS, NOTHING I HAVE TRIED WILL CLEAR THE CODE, WHATS WRONG
Krazytech
  • 725 Answers
SOURCE: frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Posted on Jun 12, 2008
SOURCE: kenmore, F1
I ended up having to buy a new oven after having someone come out to try to service the oven. It was a bad control panel and I guess they do not make the parts to fix mine anymore.
Posted on Mar 12, 2008
  • 52 Answers
SOURCE: Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Posted on Mar 25, 2008
localwonder
  • 6784 Answers
SOURCE: F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
Posted on May 20, 2009
oldTech2332
  • 2341 Answers
SOURCE: what is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Posted on Aug 10, 2011
Testimonial: "thanks for the reply, you have been very helpfull. I will now start looking for a new control board."
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
My top oven shows F1 and keeps beeping what is wrong?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 18, 2011 | Frigidaire PLEB30T8A Electric Double Oven
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
Aug 11, 2009 | Frigidaire Ovens
GE Profile Double Oven F1 Error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Help our frigidare double oven is locked and we cannot get the chicken out....it keeps beeping and showing an f1 symbol
Press Clear/Off to stop the beeping... then press clear/off again. If it doesn't unlock - wait about 15 minutes for it to cool down.
The F1 error means the EOC (Electronic Oven Control) board has a failure - and thought there was a run-away temperature condition.
It should allow itself to unlock after a few minutes of cool-down.
For additional help in finding a replacement part - a Model # will be required.
Thanks for using FixYa!!
Jun 26, 2009 | Frigidaire Ovens
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Fault Code F1
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
158 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
