Question about Technics SL-1200MK5 Turntable
Technics 30th Aniv Edition - help with break speed.
I've started messing around with the break speed on my deck, thing is it went from slow stop to so fast that the plate goes backwards now when it stops and I can't seem to fix it...
Turned out that i didn't have the right screwdriver, so I went out and got one. That sorted it out, it is really sensitive. But now it's all good.
Thanks for helping.
Posted on Nov 05, 2007
  • 382 Answers
Do you recall the adjustment you made? That brake switch under the hod is real sensitive. For starters, try pulling back half way from which you adjusted, to get a sense of sensitivity. Did you alter the pitch switch at all?
Keep me posted.
Posted on Nov 04, 2007
Technics tape deck-rs-tr515 tape starts then stops-does it need a good cleanig
Hi there! A good cleaning will help with the fidelity of the machine but if I understand your problem then it can only be that the machine needs a good service like lubrication and new rubber belts capstan roller and so on.Try your tapes on another machine and check how the sticky cassettes I have seen ruined very expensive decks.
Oct 03, 2014 | Technics Audio Players & Recorders
There are 2 problems with the my deck: 1. The +-0 light for the pitch will not work but everything else about the pitch works fine. 2. The deck will not change from 33bpm to 45bpm, I have replaced the...
Hi, please do this test for me. With the deck running on 33 speed and the pitch control set to 0 use your finger on the platter centre and speed it up manually as much as you can. Doe's the quartz lock lamp come on? If not then open the deck up and loosen off the fixing screws on the circuit board that has the 33/45 buttons. Try to change speed with the board loosened off. If none of the above makes any difference replace the quartz lock neon. Use only original Technics neon. As a matter of interest have you done any mods to the deck? Cheers John,
Sep 29, 2011 | Technics SL-1210 Turntable
I have a technics slbd20d for about 6 yrs. teh speed started to fluctuate, so i replaced the belt, with an orginal replacement from panasonic, and one from lp gear to match my turntable. but the speed is...
u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
May 05, 2011 | Technics SL-BD20D Turntable
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Aug 15, 2017 | Little Tikes Cozy Coupe 30th Anniversary...
Hi there. although my mk2 plays normally,sudenly i cannot hear it. i`ve checked wires and cartridge, what else it could be?
You need to check that the signal is getting to the amp. This can be done by removing the wires off the cartridge for the left and right channels. With the amp on touch the ends of the wires. If you hear a buzz the signal is getting to the amp and the cartridge is dead, but if you hear nothing and if the wiring is as you say good. Then the pre-amp in your amp for the cartridge has failed. This pre-amp will only affect the record deck and no other functions. If it has gone you can trace the wires from the sockets to it. Sometimes it will be on a seperate PC board. It's often a single IC that has failed. If you can replace it yourself be careful with the new one as these are often static sensitive chips.
PS the phono scokets on the amp sometimes buzz if you pull the plugs in & out!
Aug 08, 2010 | Technics SL-1200MK2 Turntable
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Deck speed up to uncredible speed and wont stop
You both have issues with your drive circuits. There is no easy fix for this. You will have to take it to a repair center to have them serviced.
There are 4 main Integrated Circuits that control the speed/drive and any one or all may have gone bad. We are seeing this alot with these units now.
Wish I could be of more help.
The 1200s Expert
DJ Pro Audio
Aug 23, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
Feb 14, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK5 Turntable Logo
95 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
