Question about Curtis-Mathis Televison & Video
I have an older Curtis Mathis tv, not dvd friendly. The problem with the tv is that the volume seems not to be working. Volume is very low and all attempts to increase the volume fail.
    Brigadier General:
  • 3,917 Answers
Check the volume setting on the TV, then check for a speaker on/off in the menu or on the back of the TV set (it also might be labeled internal/external, since some TV set manufacturers meant their TVs for home theater).
Also, if you're using a cable or satellite set-top box, DVR, or other device, check the audio connection. If you're using HDMI, make sure that HDMI audio out is enabled on you set-top box. Switch the audio back to the normal stereo, or mono channel on your television. We can't tell you how to do this since every make and model uses a different method. In general, look for a button marked SAP or audio on your remote control. If it's not there, you will probably have to find it in the on-screen menus of your set. Of course the best way is to find your owners manual and follow the directions there. To give you a reliable diagnosis I would need to know the model of your tv and the cable supplier or what kind of box you are using.
IF: The cable box connects with your tv by one coax cable and connects into the antenna input on the tv then problem is likely in the sound detector stage of the tv.
IF2: The cable box connects to your tv by three cables; one for video and two for audio, then the problem is likely a poor cable or connector. In this case, try the audio cables into the same inputs that give good results with the dvd player. Still better; switch the dvd cables over to the cable box audio outputs and see what you are getting.
IF3: There is a loose connection or cold solder joint that is causing the poor audio with tv/cable, then try the old vibration/whacking test. Smack the set with your hand or fist in a few strategic places to see if you can restore the audio that way.
Let me know if you need more ideas.
Cleggsan
PS: Another test; if you live anywhere near a tv transmitter, disconnect the cable and try with rabbit ears or any external antenna to see if you can get good audio from a local station. If it is bad that way, then it is certain the problem is in the sound detector stage of the tv. If the audio is good with local stations, the problem must be in the hookup between the cable box and the tv input - such as the bad cable mentioned above.
Thanks for contacting Fixya
Posted on Jun 21, 2009
I can't access the advanced settings on my Curtis-Mathis TV
is it possible to connect my toshiba regza rv75 tv to the internet
Dec 15, 2013 | Curtis-Mathis CM19011 TV
The volume on my curtis mathis television is not working properly. the numbers are low but volume is high.
There is some fault with the control section to volume circuit. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Curtis-Mathis CM32010 TV
I do not have a credit card. I have connected my wireless headset to the TVs audio out on the back and it works great. My problem is I can not mute the TV speakers, so the sound is comming from both...
Try just turning the volume down on the TV. The audio power to the red/white output jacks should be the same at any TV volume since it is expecting you to control the volume with an audio receiver or other amplifier.
Good luck.
Please rate me
Mark
May 05, 2011 | Curtis-Mathis Televison & Video
I cant find my remote, and my TV's volume buttons seem to be stuck. I need to be able to turn the volume up and down, but they wont do anything. Do any other remotes work with this TV, or am I out of luck?
HMMMM....you have a bad capacitor in the deflection area of your TV. This bad cap will raise the high voltage to a level unaccustomed to the power supply. Eventually this TV will shut down. You will need a tech to find the capacitor or two and replace them. This will lower the voltage to a proper and working level. The remote or universal one, will not operate your TV properly at this time. A common problem for your Curtis Mathis. Thanks for asking and show a few hands of support.
Jan 27, 2011 | Curtis-Mathis CM27101S TV
Setting up this system, i can t adjust the volume when attached to the TV with the RCA leads. Seems to come through at a set volume. Works fine on its own, but cant hook it up with my excisting system
Drawing audio from a TV has its limitations. Refer to the TV's manual regarding volume control of the audio OUTPUT.
If you MUST go this way, I'd still suggest using a Fixed output so you can turn the TV's speakers down or off without killing the signal to the Curtis. (TV's are on the low end of the audio food chain and actually will degrade rather than improve it.)
You could get the BEST possible TV-related audio directly and digitally from the source you're watching.
Jul 03, 2010 | Curtis DVD5091 Theater System
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Mar 09, 2008 | Curtis CM13102 13" TV
No volume
I have no volume on my tv I can't figure out why?
Dec 27, 2007 | Curtis-Mathis CM19011 TV
Televison & Video Logo
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
