Question about Electric Delco MB1718 Mini Brute 1700 Psi Hot Water Pressure Washer
Radio in safe mode
I have recently had my opel/vauxhall astra car serviced, the battery was disconnected and now requires a code to operate the radio.
Can anyone tell me where to find this code as i dont have a manual or possibly tell me what the code is?
The radio model is Delco Electronics.
    Problem Solver:
  • 4 Answers
Had the same problem, look in your local ads or ask in a good car parts shop ( may have number or card ) for someone doing code unbocking. This should cost about 15 quid and take about 15 mins and done at your home. Generally quicker and cheaper than your dealer. Oh yer and the code of your choice. Hope thats helpful.
Posted on Sep 20, 2009
  • 70 Answers
You can obtain the unlock code from your local dealership service center
Posted on Jun 21, 2009
Vauxhall astra radio code lost
On radio or car manual; there must be attached label which shows radio serial number. You must contact to opel & provide that radio serial number in order to get acivation code for your car radio. As far as i know; there is no way to work original radio without having activation code.
Nov 19, 2014 | Car Audio & Video
Astra coded radio cant enter code??
I would suggest that your radio got a voltage surge when your battery was recently removed and re-connected. I would either:
1) Remove radio (if you have the special tool), unplug and re-connect harness, or
2) Pull the fuse in the fuse box for the radio (may be two), or
3) Disconnect the negative post to the battery, wait 30 seconds and re-apply (very quickly).
If the display does not reappear, I'm afraid the radio is damaged. Let me know.
Dec 18, 2013 | Car Audio & Video
Hallo radio code opel astra vdo siemens gm050021461711
Unfortunately the code for a Vauxhall VDO/SIEMENS radio is only available from the Main Vauxhall Dealer or a Radio Decoding Service only.and will not be available for free (or cheap) from anywhere on the Internet
This is because access is required to the original factory database....and this is not commercially available.
Sorry.............
Jan 03, 2011 | Car Audio & Video
Free unlock code for my Delco CDR500 radio in my Vauxhall Vectra
Hi I have just bought a car and it is in safe mode the car is a vauxhall vectra and the stereo is a delco electronic cdr 500 and serial no on it is gm0500t9120228 pls can you help me thanks Brian
Oct 23, 2010 | Car Audio & Video
How do i recode my car radio its saying safe i av the code my batt went flat its a 2oo1 vauxhall astra
try leaving the radio on for an hour or two and see if it exits safe mode.
Aug 16, 2010 | Car Audio & Video
Stereo code for vauxhall astra cdr500
Unfortunately the majority of SIEMENS/VDO codes
(including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Mar 30, 2010 | Car Audio & Video
I have a vauxhall astra with a cdr 500 cd player in it but it will not play any cds or radio and keeps sayin error TR_ _ _ CD
From what I have been told, you would need to reset the unit. With a reset, basically disconnecting the battery cable you would need a four digit code. It was one that came with the car or the radio. It will put it into safe mode as if the radio was stolen. Once it is in safe mode you would then need to punch in the 4 digit code. That will reset the unit and allow the radio to begin working. If you do not have the 4 digit code you would then need to take it to a dealer and have them reset the code. I was told it would only be about $25 at almost any dealer.
Oct 28, 2009 | Car Audio & Video
Radio code for vauxhall corsa
The units anti-theft program was activated when the battery was disconnected. If you don't know the 4 digit code, try to contact the previous owner or most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Car Audio & Video
Entering Code for Car Stereo
Turn on the ignition, turn the radio off fully. (by preeing the volume wheel knob) press AS or the button that turns it to CD mode (should have circle on button)keep it pressed and turn radio on. wait for a beep then it should be somthing like:
10----------- (10 being the number of tries left)
use buttons 1,2,3 & 4 to input your code. press the button more than once for it to rise higher.
Hope this helped.
BTW i got the same problem with my dads astra. but i dont even know the code :(
Nov 24, 2007 | Car Audio & Video
Electric Delco MB1718 Mini Brute 1700 Psi  Hot Water Pressure Washer Logo
643 people viewed this question
Top Electric Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Electric Measuring Tool and Sensor Expert? Answer questions, earn points and help others
