Question about Juki Sewing Machines
Thread and bobben pattern for juki ddl 5550 machine keeps cutting bobben thread
Your bobbin case may be too tight. Try loosing it by turning the small screw a little turn to the left. If thats not it, you could also have a bend or snag in the bobbin case that is snapping the thread. If this is the case you will need to replace it.
Posted on Apr 21, 2010
Error code E3 45786 on Juki sewing machine motor
I could not find that error using the Manual that is on the Internet.
I suggest you call or email their Sales and Service in the U.K.
Their email is sew-europe@btconnect.com
JUKI DDL 5530 DDL 5550 Parts Needles Service
Feb 16, 2015 | Juki DDL-5550 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
Hello. My sewing machine DDL 5550-6 display shows the problem. E7. What is it? And how do I fix it? Thank you
HI THERE
concern E7 there's many reasons :
1- machine jamd ( try to turn machine by hand if you found handwheel is move easy ok.
2- thread trimmer locked or release? sometimes E007 come at the time of thread trimming function activated.( please check timming cam for thread trimmer ).
3- sometimes some threads go insaide hook and machine stop and give E7.
best regards
ashraf abozid
CAIRO - EGYPT
Mar 30, 2011 | Juki DDL-8700
Hello, I have a juki DDL 5550, runs great, But the tension is off. Top thread bunches up on bottom side of fabric ( bobbin thread looks ok)\r\nThanks,S
Soulds like your not geting the top thread all the way in the tension disk. Make sure you have the presser foot up when you thread the machine. also after you get it treaded check to make sure you have tension, with the presser foot up you should have not tension and with it down it should be very hard to pull.
hope this helps
Mar 15, 2011 | Juki DDL-8300
I need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
Mar 30, 2010 | Juki DDL-8300
I just got a used juki ddl-5550-6 sewing machine. There is no owner's manual. I think I have the machine threaded right. When I put the pressure foot down to start sewing, it pulls the thread down into the...
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
Jul 08, 2009 | Juki DDL-8300
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
398 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
