Since you didn't state the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: number of rings
two rings means it has message, erase the message to increase the number of rings to like four
SOURCE: VTech model TM3111-2 the time
Assuming you are using T-Mobile@Home for your telephone service you should then;
type into your web browser address bar - 192.168.0.1
On the 'Setup' Tab with the sub category of basic setup look down towards the bottom of the screen for 'time setting.'
Click in the arrow for the drop down box and select your appropriate time zone.
Click on 'Save Settings' and you should be good after that.
SOURCE: Mitel superset 4025 - setting up a number to forward phone to
It is probably a system speed dial number. What mitel system do you have?
SOURCE: need to program phone numbers
Hi!! Follow the link and you can download the manual. Hope this helps!!
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314056
Testimonial: "Thank you very much for the prompt response, Greatly appreciated"
