Question about Kenmore 73952 Gas Dryer
My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
    Problem Solver:
  • 18 Answers
Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
Posted on Jun 21, 2009
Kenmore dryer not heating up
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 10, 2015 | Kenmore Dryers
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
May 20, 2014 | Kenmore 80 Series Heating Element -...
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Dryer is taking too long to dry
Dryer needs to be cleaned. Unplug, take off back and vacuum all lint out of dryer, also take off vent and vacuum inside of vent area. Then clean dryer vent from inside of house to where it exits. Make sure all lint removed. Lint holds moisture and causes dryer not to be able to release steam caused by heating wet clothes, thus clothes don't dry.
Jun 09, 2010 | Kenmore 66972 Dryer
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
May 15, 2010 | Kenmore 400 6942 Dryer
My Kenmore 600 is not even 2 years old. It spins and appears to have heat but the clothes do not dry. I cleaned a ton of lint from the flex pipe/elbow joint in the rear of the dryer but this has not...
You are on the right track by cleaning the vent elbow.
Also check:
The entire vent line to the outside diverter (the little thing that looks like a hood). Depending on your dwelling, the vent line can also become obstructed with lint and sometimes other things like bird's nests, especially near the discharge outlet. This can happen when the flapper valve at the outlet sticks.
Make sure the lint screen is always kept clean
Another thing to try - empty the dryer and pull it away from the wall until you can get behind it. Disconnect the vent line and turn the dryer on air only. The air velocity coming out of the dryer air exhaust line should feel pretty strong. If it doesn't, the fan could be full of lint as well or there could be an issue with the exhaust fan itself. If the fan is plugged or bad, the back of the dryer will have to be removed and the fan checked.
The dryer should not be overloaded and be sure the clothes being dried aren't too wet (possibly indicating a washer spin cycle issue).
Jan 01, 2010 | Kenmore 62602 Electric Dryer
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 73952 Gas Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
