The transparent film strip has fallen of where does it attach to on the canon pixma mp460
    President:
  • 2,306 Answers
The strip needs to be clean, there is an arrow on one end, needs to point up on the left side. Behind the carriage unit is a small slot that the strip passes through, a silver spring on the left to hook through the hole on the strip, and a solid metal tab on the right to hook the other hole to. It's not as easy as it sounds, especially with all the covers on...
Posted on Jun 22, 2009
Scan slide negatives film
I have had that problem with the MX310.
depending on what IOS you are running
you can get software free that will scan
Transparencies "opposite"
Oct 12, 2013 | Canon Pixma MX410 All-In-One Printer
I have a Canon MP150 printer. I would like to print on my "ink jet transparencies", but there is no option for "transparencies" in the paper options. What should I use as the paper...
Use the paper option, BUT you need special inkjet transparency film. If you use normal transparency film the ink cannot dry properly and will streak.
Jul 01, 2011 | Canon PIXMA MP160 All-In-One Printer
P2 error
P02 (Carriage error)
  1. Make sure no foreign material stuck to the print head railway.
  2. Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.
visit this link for more info
http://pcmediks.blogspot.com/2010/10/canon-pixma-mp258-error-code.html
Dec 28, 2010 | Canon PIXMA MP240 All-In-One InkJet...
ERROR 5100
hi;
remove and clean the timing strip film carefully ; it can resolve the problem
Oct 19, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Alarm is flashing error code 5100 and won't let me print anything
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My Canon MP460 has malfunctioned and Windows doesn't recognise it
Check your user manual for instructions on how to reset the printer to factory defaults.
Oct 12, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
Canon prixma mp460
http://drivers.softpedia.com/progDownload/Canon-PIXMA-MP460-MP-Drivers-xp64-101-Download-50565.html
download from here if u have xp.
but if u have othe ros letme know i give u link for that os also.
Nov 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
64 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
