Question about Garden
I'm trying to start my Briggs pressure washer that has not run in a year. It wants to start after I prime it but will only run a few seconds. I can repeat this process over and over with the same results each time.
    Scholar:
  • 106 Answers
Hi...
Sound to me like your not getting fuel to the engine. There should be three controls on the pressure washer.
1. on/off kill switch
2. choak which should be on until your engine starts and warms up. Then move it mid-range
3. gas which when starting and when engine running should be opened all the way. This control should be right next to the choak.
I'd check and see if you've got your gas (no. 3) opened and supplying the engine with fuel...
thank u
hope this will solve ur problem...
Posted on Jun 21, 2009
The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
Hello i have a 6 hp briggs pressure washer and it starts fine and runs for 30 seconds and shuts off. it feels like the motor gets stuck when i try to start it again, but after a half hr or so it will turn...
You have to make sure you are pressing the trigger while you start the pressure washer. You should also make sure you are releasing the pressure at least every 30 seconds or the pressure will build in the pump and the engine can stall.
If it stalls with pressure in the pump and you don't relieve it by pressing the trigger, it will be very difficult to start. The pressure will slowly bleed off over time, which sounds like what you are seeing.
Jun 07, 2011 | Briggs & Stratton Gas Pressure Washer...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
May 23, 2010 | Briggs & Stratton Power Products 1539...
Engine won't start
Try spray starting fluid into the air intake, that may get it going.
Sep 26, 2017 | Briggs & Stratton Prosumer 20324 Gas...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
