Question about GE Refrigerators
Flap for ice dispenser does not work - GE Refrigerators
  • carlkroll Jun 21, 2009
    Thanks, but the flap does move freely when doig it by hand
  • 3,600 Answers
Most likely the flap has frozen pull the Ice maker out and operate the ice dispenser push the dispenser flap and see if it it is free, if not pour warm water on it to free the flap.
Posted on Jun 21, 2009
  • Bruce Hathcock Jun 21, 2009
    can ya send me a picture of it?
THE ICE DISPENSER FLAP IS NOT CLOSING ALL THE WAY
There is a solenoid that operates the flap, although there are many other components that could be broke but usually its the solenoid
Jul 22, 2015 | Frost Refrigerators
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
The flap on the ice maker dispenser will not close.
Problem with these flaps are that they have plastic hinge which work great for sometime when they are new and have shiny inner surface but with use they develop minor scratches which cause resistance and hence partial closing. Either get the flap replaced or apply Vaseline jelly in the moving part of the hinge.
Apr 23, 2013 | Refrigerators
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
461 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
