Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Our refrigerator is leaking very slowly and we can't find the source. I've traced the line to the ice-maker and water dispenser, and it appears bone dry. So little water leaks that even after a few days, the towel we put underneath is barely damp. But left alone, it's warping and damaging the hardwood floor. Any suggestions? Do I need a plumber or an appliance repairman?
The hose that drains the water from the defrost cycle could be plugged up. It is located in the bottom of the freezer section and goes into a tray under the refrigerator where it evaporates.
Posted on Jun 23, 2009
    Sergeant:
  • 340 Answers
Its condensate the drain line may be missing the pan you can access from the bottom in the back. i'd call for service if the floor is getting damaged. Tom
Posted on Jun 21, 2009
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
My fridge just started running water from under,not just a Lil drip,I even have to shut the main water line off....what do I do now?.
My refrigerator did this when the fridge temperature control door got stuck open and froze everything in the refrigerator. I tracked down the problem to a connection in my water supply filter. I just removed the filter and spliced the line. I doubt the same thing happened to you but you can probably find the leak by tracing the water supply to the ice maker/water dispenser.
Feb 21, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung refrigerator problems
Well you will have to trace out the water line and see where leak is coming from .If you disconnect everything and pull on that water hose it would come out BUT do it slowly
Dec 22, 2017 | Samsung Refrigerators
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I remove the ice tray from LG Refridge Model # 25976
You have awater problem not an icemaker problem...inlet valve bad or water source problem....
Oct 02, 2012 | LG LFX25976 (247 cu ft) Bottom Freezer...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
Nov 29, 2008 | Refrigerators
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
233 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
