Question about Dryers
Need to restart pilot? i turn the dryer on and it makes a sound as if it is running, but nornally i hear a little boom when the gas kicks on, and now it just runs and does not get hot
    Problem Solver:
  • 18 Answers
If you can open the bottom panel you could see the gas valve. Turn the dryer on and watch the valve. If it glows (ignitor coil glows and turns flame on) and goes out then it is a problem with the valve. If it doesn't glow at all it could be the coil or a blown safety thermo
Posted on Jun 21, 2009
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
https://www.youtube.com/results?search_query=Whirlpool+gas+dryer+pilot+light+goes+out+quickly+or+doesn%27t+stay+on
Oct 28, 2015 | Whirlpool Dryers
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Whirlpool Dryers
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have an amana furnace and it will not kick on. When the switch is turned on the furnace will try to run but won't warm up and blow. Does it have a pilot light?? or a reset button??
Try this----turn furnace off at stat and unplug furnace for 10 minutes. Plug it back in, the combustion and blower motor may both kick on for 2 minutes or so or not. Turn t-stat to heat and turn up stat to highest setting. Hurry out to furnace and you should hear the combustion motor(little motor piped to flue) kick on, then wait for a "click" next you should see a glow from the igniton element, then another click, next will be the gas valve opening. If no ignition, it will try 3 times and then lock ur *** out, and just turn on the blower just as a precaution. If you dont see the glow plug glowing after the first click, replace the $20 glow plug and you should be good to go. The glow plugs crack, and this is what breaks the connection. If you gas valve has a knob, and says pilot----turn the valve to pilot, push down on the knob, light the pilot and hold down knob for 2 minutes to heat up flame sensor. Make sure the t-stat is all the way down or off. After 2 minutes of holding pilot knob down, let go and your pilot should be still lit, if it is, then turn gas valve to ON and then turn t-stat up to kick on furnace. If ur pilot doesn't stay lit, get a new thermal couple and replace it-$12 bucks. Good luck and let me know how it went. azeddysac@yahoo.com
Nov 06, 2010 | Heating & Cooling
Dryer pilot comes on for about 5 secs and goes out, but burner dosn't ignite.
your pilot need to be check , most likely it is old and need to be change.
if it is old it will go on but not strong to signal the gas to kick in so it just go on for a few second and then when it feal no gas it turn off.
if your gas supplay is good then thats your problem the ignitor (pilot) good luck
May 01, 2010 | Whirlpool LGB6300 Gas Dryer
Hooking up my dryer
There is no pilot light on your dryer it sounds like you have a gas leak somewhere. Get a cup put alot of dish soap in it and a little bit of water and apply it to your fittings in the back. If you have a gas leak it will bubble up. If this is a used dryer you may have a damaged gas valve or another internal leak.
Jan 22, 2010 | Estate TGDS840JQ Gas Dryer
There are two at the beach and they won't stay lighted. The pilot kicks on, then you hear gas, then it ignites with a big swoosh and immediately goes out. This happens over and over.
Sounds like the pilot sensor is dirty if you can see where the pilot light burns the will be a metal rod that senses the heat of the pilot and tells the burner it can come on. clean the rod with steel wool. even a little build up can shut the burner down.
Aug 12, 2009 | DCS Large Appliances Outdoor Heaters
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer tumbles but doesn't heat
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
Marvin
Marvin
