Question about Yamaha HTR-5740 Receiver
Can't seem to get any music from the turntable
The only time I get any sound with the turntable is if I turn it up to the top...and then there is considerable static (obviously). I have hooked my turntable up to my old system and it works, but not with this one...any ideas.
  • 1 more comment
  • theneebthree Jun 22, 2009
    Smarthome2
    Thanks for the quick feedback. I have the ground terminal on my old reciever, but not this Yamaha one. Any others solutions
    Thanks Smarthome 2
    My old receiver has a turntable input with a ground; however this Yamaha reciever does not have a dedicated turntable input; nor can I find any ground terminals other than for a FM/AM
  • theneebthree Jun 23, 2009
    SMarthome2...I guess I know where you got your name...works like a charm...many thanks
    President:
  • Yamaha Master
  • 1,114 Answers
Do you have the ground wire from the Turntable hooked up to the receivers ground terminal? it's a screw down silver nut and should be next to the Phono input. You are just lacking a ground from the turntable to the receiver. If you don't see a wire from the turntable, look around the chasis of the unit and you will fins it. Hope this helps
Posted on Jun 21, 2009
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
I just purchased the AT-LP120-USB - it's was a beast to get the thing balanced correctly, but now i hear some very obvious crackling sounds that weren't there before when the tone arm wasn't...
as long as you have balanced your tonearm correctly, maybe its simply just a problem with your vinyl? could just be dust in the grooves or could be static build up, try cleaning your vinyl with an antistatic cloth to see if the sound improves.
May 05, 2011 | Audio Technica AT-PL120 Turntable
How do I eliminate static when I am recording from the ION USB Turntable to my Apple?
Static can be elimited by having a piece of wire running to earth. Many turntables have an earth connection. If it's the records themselves that are causing the problem you can get an anti-static record cleaner. I will post the website for one that I use all the time.
You can also get an anti-static record matt for turntables.
http://www.soundswholesaleltd.co.uk/acatalog/index.html
Jul 05, 2010 | ION Audio iTTUSB Turntable
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
I just hooked up my old amplifier to my turntable and started playing some vinyl. I'm getting an incredibly annoying static sound through the headphones I'm listening through, and I'm positive it's not the...
Make sure the ground wire from the turntable (they all have one) is grounded to the amp, also the turntable has to be connected to the phono input on the amp. Turntable cant connect to cd or aux. Only phono. Also check to see if there is dust and dirt built up on the needle. clean if needed. most likely a grounding issue
Dec 05, 2008 | Audio Players & Recorders
Turntable power seems to be lightly surging
Sounds like a voltage regulator on the mothboard is going out. Avoid going in there, you really could fry yourself poking around in there. Check out these guys. They're top notch
http://www.repairnyc.com/
And Technics authorized.
Jan 12, 2008 | Technics SL-1210 Turntable
Yamaha HTR-5740 Receiver Logo
330 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
