Question about Car Audio & Video
No power to the amps and no sound
The head unit has power and the EQ has power but there is no power to the capacitor and the amplifiers it has worked for 4 years with no problem until now I was wondering if the Lanzar EQ has gone bad because I have a manual switch to my eq and when I usually turn it on I here the power go through the speakers, but now you here nothing but the eq does have power.
  • 578 Answers
Check you main power fuse you put in the frnt on the battery fuse on the amp and all your ground and remote power source you will find the problem
Posted on Jul 07, 2009
IBENEZ BASS AMP P500H NO SOUND
I had a short at one of the electrolytic capacitors at the EQ board. Check the voltages!
Apr 11, 2014 | Ibanez P500H Promethean Bass Amplifier...
What size preamp equalizer do i need for a 2000 watt amplifier for car subwoofers?
There is nada wrong with your preamp and changing it will accomplish nothing. If your channels are allegedly clipping it is due to the fact that it is being over driven. A bad preamp could not over drive your amp!
Have to be careful with tone controls at high levels. Every 3db increase compels amp to double power at that frequency. So if you are blasting at 2000 watts and you boost a control by that amount, your amp will put out 4000 watts and clip. If plus 6db then it is 8000 watts!
Jun 19, 2017 | Hifonics Car Audio & Video
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Car amplified speakers...massive bang...
This kind of problem is often caused by transients in the signal
processor as it powers down finding their way into the signal path,
which the amplifier then transmits to the speakers.
Usually this can be solved by adding a little turn-off delay to the
processor. This allows the processor to stay powered on for a short
time after the amplifiers have powered down, thus preventing the pop.
Many components sold today (such as crossovers, equalizers, etc) have
delays built-in. Read your manual to see if it is possible to set this
delay on your piece of equipment or be sure to look for this feature
during your next car audio purchase.
If your processor does not have this feature, you can build your own
delay circuit with a diode and a capacitor. Add a 1N4004 diode in
series with the processor's turn-on lead, striped side towards the EQ.
Then add a capacitor in parallel, the (+) side of the cap connects to
the striped (processor) side of the diode, the (-) side of the cap goes
to ground (not the radio or EQ chassis - connect to the car chassis).
Experimenting with the cap value will give you the right amount of delay
before the EQ shuts off. You don't want it too long, just long enough to
make sure the amp is off before the EQ powers down. 220 - 1000 uF is
about right, and make sure the cap is a polarized electrolytic, 16V or
higher. Also keep in mind that the diode will introduce a 0.7V drop on
the remote wire, which can cause the processor to power down before the
rest of the system.
Apr 19, 2009 | Car Audio & Video
Any ideas?
CHECK YOURE EQ OR TRY TO BYPASS THE EQ FOR TESTING
May 08, 2008 | MTX Thunder 1501D Car Audio Amplifier
Mtx 1501d
ARE U USING THE CONTROLS THAT CAME WITH THE AMP?
USUALLY THE CONTROLS CABLE GOES BAD
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
My car amp works produces distorded noise . As I plug in the rca cables i noticed that if just the tip of the connector touches i get a good sound but if i insert the whole connector it becomes distorded...
You have a grounding issue.
The RCA inputs of the amp are many times NOT tied to chassis ( the chassis of the car ) ground.
Same goes for the RCA outputs of your head unit.
The speaker outputs of your amp SHOULD NOT EVER be tied to chassis ground.
  • make sure that no speaker wire from the amplifier is touching or attached to ground.
  • Make sure that your amplifier ground (GND )( of the 3 power inputs.....GND, +12V, Rem) is securely mounted to a bare metal spot on the frame. Best practice is to have the amp GND, and the head unit GND at the exact same physical point.
  • Make sure that your RCA cable shield ( not the center tip, but the part around it ) is not touching the chassis.
  • Make sure that you have not nicked the wire while installing it and are accidentally getting a connection to the frame of the car.
  • Make sure that the head unit is grounded properly.
  • IF for some reason you have an equalizer between the head unit and the amplifier, make sure it has its own switching power supply INSIDE the EQ.
Bad grounds are a pain to troubleshoot......best of luck....Rob
Mar 17, 2008 | Audio Players & Recorders
HOOKING UP???
im looking of wiring diagram of proline equalizer model GP-870XII
pls can i have a favor to send at my yh act serra_ricky@yahoo.com
tnx!~ and more power!
Sep 15, 2007 | AudioControl EQL 13-Band Car Equalizer
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
