Question about Home
Regal Sloan Valve operates only intermittently
It operates for a couple days and then won't flush. Turning the water supply off, then back on, will restart the flushing function.
The inner parts of the flushing system are new.
Sloan manual valve will not flush unless water is run in sink next to toilet
Posted on Apr 22, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
The diaphram has a little metal by-pass or air-flow hole thats probally stopped up or the vacumn breaker is bad.
Posted on Jun 21, 2009
I have a push button flush on my toilet but the flush is getting less powerful and we have to wait ages before it will flush again despite the water level filling quickly????
Sounds like the syphon unit has scaled up. You can try flushing with a descaler fluid a couple of times to see if that will loosen the scale but otherwise replace the plastic syphon within the system. Cheap part, relatively easy fix if you know bit about plumbing. Confidence is the key.
Dec 13, 2014 | Home
Toilet not flushing correctly :why does tank not fill so that it will flush
the fill valve is not letting water in you either have a float that raises up when water is full so when you flush the float drops down letting water in then when water raises it shuts off i would replace the float fill valve and corky flapper.... here is what you do .... first shut water off where it goes up to the tank....... flush commode to empty as much water from tank....... reach up under tank there is a plastic coupling that connects the water supply line to the bottom of the toilet tank...put a small pan under the shut off valve that goes to the toilet some water is going to drain from the tank when you take the coupling loose..... turn the coupling counter clockwise ( use a channel lock adjustable wrench to loosten then had turn) once this is loose you can pull the riser tube away from the tank...... now there is a plastic nut that screws the shaft to the bottom of the tank loosten with channel lock then remove with hand by turning counter clock wise ( you will get a bunch of water flowing down to the pan) remove the entire fill valve , replace with a fluidmaster fill valve ( about 8 bucks from big box store when you take the new fill valve out of the box there is a neopreme seal you must put on the new threaded shaft ( it has an inner ring you may have to punch out) once you put this on you can insert the entire shaft down through the hole in tank then secure with thin nut provided tighten but do not overtighten then put coupling back on,,,,,put the over flow tube on the tit of the fill valve and stick down into over flow ok thats done when you go to big box store purchas a 5 buck corky flapper (red caus it can handle chlorine water better) remove the old one at bottom of tank( just two clips to remove and chain attached to flush lever...install new one be shure chain does not have a lot of slack so it does not fall under flapper seal when you flush......OK YOU ARE DONE TURN WATER ON WATCH TANK FILL LOOK FOR LEAKS TAKE A TOWEL AND DRY ALL AREAS THEN TAKE YOUR HAND AND FEEL FOR LEAKS UNDER TANK AND DOWN TO SHUT OFF VALVE .....CONGRATS YOU DID IT!
Jul 31, 2014 | Kohler Home
Motorhome toilet won,t flush
Make sure the water supply to the toilet and the pump are working properly, make sure waste tank is not full, if it still won't flush check the flushing mechanism on the toilet.
Mar 01, 2014 | Sport & Outdoor - Others
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Have old kohler, i do not know what the inside flapper part is. However toilet will flush but tank will not fill. I can turn thhe water to the tank off and turn on again and it will fill
This indicated that there is dirt of corrosion in the flush valve assembly that get jarred loose and flushed out when turning on the supply valve below. My recommendation is replacing the flush valve assembly with a Fluidmaster flush valve. Be sure to follow the instructions when removing the old valve and installing the new one. If you need step by step instructions, please message me and I will provide them.
Dec 05, 2010 | Kohler Home
Have a urinal flush valve which has insufficient water discharge. Unit is supposed to dispense 1 gallon, but I would estimate only about a half liter flush. Any suggestions?
The guts have worn and the hadle does not push the internal plunger far enough. Check your local plumbing supply house for a rebuild kit. The kit can be installed in a couple of minutes.
heatman101
Aug 20, 2010 | Sloan 3010100 110 Water Saver 3.5
How to drain and flush radiator
at the bottem on the left or the side there is a small key like screw ( righty tighty lefty lucy } then u must remove the radiator cap and also remove the themastate be sure to attach the therma housing and hose and unatch it at the top of the radiator the put water hose in the open cap area and flush for 20 mins turn on engine and let run for 2 min and repeat flushing untill all antifrez desapears. be sure to put every back tack pitchures as you remove so to put back the same way it might be good to get new thermastate
Jun 25, 2010 | 1998 Ford Taurus
Home Logo
381 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
