Question about LG 37LP1D 37 in. LCD Television
Sound but No Picture
Hi, I really hope someone can help. I've had a LG37LP1D for just over a year now, but I switched on the TV this morning, and there was no picture.
I've checked all the connections to the periherals (Digital Box etc.) and everything is fine as I have sound. I think I have a problem because the start-up screen of the TV does not appear.
I switch the TV on and and it makes the usual noises, but when I expect the LG logo to appear on-screen at start-up, it doesn't appear. The TV screen remains black where/when the logo should appear, then it gets slightly brighter when I think the actual TV picture should appear, but I still cannot see any real TV picture. (I assume this means the lamp is working fine etc.)
Please Help, Naz
  • 2 more comments
  • Zeeman2k Nov 03, 2007
    Sorry, in addition, if it helps, I cannot see any of the on-screen menus either. Thanks.
  • Zeeman2k Dec 06, 2007
    Hi Bruce, thanks for trying, but that's definitely not the problem. I can't even see a menu to look for picture settings!
    Thanks anyway, Naz
  • Anonymous Oct 12, 2008
    Occaisionally, when I turn on the TV and cable box, I get sound, but no picture appears on screen, nor does the upper right corner say that it's connecting to source as it usually does. I turn off and on a few times, then finnally I get the picture...don't want to wait too long if something is wrong, would like to get fixed while still in warranty.
  • Anonymous Jan 06, 2009
    sound but no picture
    guide works
    picture in picture works
    video games work on tv
  • 58 Answers
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Posted on Dec 06, 2007
SOURCE:
Humming sound
This type of sound can be generated by the back-light inverter board.
Jun 15, 2013 | Sony BRAVIA KDL-52XBR4 LCD TV
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
TV - Samsung LE32A457C1D White picture
This happen on all inputs including rear ones?
May 24, 2012 | Televison & Video
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
When powered on with remote,makes usual sound,green light comes on,then goes off,blinks 3 times,goes off and contiuesly blinks until unplugged. Problem is picture suddenly went black with no sound.Could it...
my samsung tv model number is sp50L7hx it's 6 years old, when I turn it on it's a not really nice picture just nice sound, after 2 hours the picture is off just sound .... after I was switch off TV and switch on again ... the picture is very bad and just for a ten-twenty minutes ... what's is the problem? I'm never change the lump ... or is it a some problem with T-Con decoders board or is it a lump?
Jun 19, 2011 | Televison & Video
No picture.... sound works
i hope so.but if you know how someone who understands electronics can be of help.
May 28, 2009 | Proton VT-218 20" TV
No picture or sound
I will need to know the model number in order to help you with a possible cause to your problem. Plaese post the model number and I will see if I can make some suggestions
May 23, 2008 | LG Televison & Video
No picture No Sound?? Tube is fine....
Hello MagillaG, You are getting off cheap considering that this hum may be from the IHVT, hopefully the hum is not for that component. Since you have no picture and no sound that denotes a power supply probme which can be anything from a blown fuse to a bad IHVT or the horizontal output transistor. $180.00 is about right.
Sep 20, 2007 | Toshiba 27AF42 27" TV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
LG 37LP1D 37 in. LCD Television Logo
268 people viewed this question
Ekse
