A circular wire (I believe a clamp ring)with a diameter of about 12 inches held in the shape of a cirle by a coil spring came loose from the front bellows seal, I believe, and was floating inside my Maytag front-loading washing machine, Model # MAH2400AWW, Serial # 14041719JT. I would like to put it back but am not sure where it goes. Please advise. Thanks.
  • ar111 Jun 21, 2009
    Please note this is a FRONT-LOADING washer (stackable) and the instructions from "How to Fix a Washer" do not solve my problem.
    Thank you for the manuals that may contain the answer I need; however, my computer won't open the links you sent. The error messages state that the links may be mispelled or there may be a problem with my adobe. I am going to forward the links to another computer to try to open them tomorrow. In the meantime, if any one has advice that can be posted right on the FixYa website or instructions that can be opened with Word rather than a pdf file. Thanks.
  • 136 Answers
It belongs somewhere in the bellows, you have to remove the rubber boot in order coil diaphram..
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170344 go to that likk and click on the tub. i believe it is part #34. check that out and get back to me
Posted on Jun 21, 2009
  • 2,071 Answers
Here the service tech manual.Just click below...
http://www.servicematters.com/maytag_library/docs/16023430.pdf
http://www.servicematters.com/maytag_library/docs/16027174.pdf
Hope it may helps:
Regards:
VOTIT
    Brigadier General:
  • 3,917 Answers
Please check out the article provided bellow for a detailed description of the probable part from where the coil spring might have come loose along with a internal diagram of a generic washing machine.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
Thanks for contacting Fixya
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
How to install front suspension 1968 bel air..... i need help!!!!
have you undone the lower ball joint? if you undo to joint and swing the arm down, you should be able to get the spring in. i assume you are using a proper coil spring compressor, only clamp ONE side of the spring so that it goes in a banana shape. believe it or not this is also actually safer. that shape will help you get it into position. make sure the coil ends are fit into the divots in the frame for them.when undoing the spring compressor, insert a line up bar through the lower control arm upwards through the spring. this will stop the spring from flying out if things go wrong.you should then be able to jack up the lower control arm into position and re attach the lower ball joint. good luck!
Apr 05, 2010 | 1983 Chevrolet Impala
My 1990 chevy astro mini-van has a loose tilt steering column. I need a diagram and instructions on how to repair it. It also needs a horn kit and new ignition switch any help would be appreciated.
Ok Here is what you need to do this job
1. #8 tork head wrench
2. # 3 tork head wrench
3. New cylinder or lock buy at junk yard or from dealer or lock smith with keys.
4. Tube of lock tight
5. steering wheel removal tool Rent it from Schucks
6. steering wheel spring compression tool Rent it as well.
7. Two dental picks to remove spring.
Now make thew wheels straight and pull the horn button off should just pop off, next you will see a nut 3/4 inch remove the nut now find the right size of threaded bolts out of the kit and put them in the holes with puller over the steering column remove steering wheel. Forgot to mention remove the metal cup and plastic ring held on by a3 philips screws. This is your horn button, next put the U shaped compression tool on the bolt that you took the nut off and compress the spring 1/4 of an inch to 3/8's of an inch. Now take the picks and get them under steel ring slide the ring over the steering bolt and pull clamp off now remove plastic plate you are now where you can get to the 2 screws on top to tighten the steering wheel. you will see a screw just at the end of the cylinder lock remove the one screw and pull the cylinder lock out, put a drop of lock tight on each screw and tighten down look to see if you see a wire by the lock ring is sticking up it will have a 45 bend in the copper wire there will be two one side by side this has to be pulled out along with the plastic holder that holds the two wires in this also holds the lock in as well as the one screw, install the new lock put lock tight on the screw and install new cylinder lock and key once you have done all of this leave it apart and get back to me so I can tell you how to remove the bueaty ring to get to the screw on the back side.
Jun 15, 2009 | 1990 Chevrolet Astro Extended
A wire ring came off
Hi Bert,
That ring (it has a spring on it, right?) is used to clamp the outside of the rubber boot to the outside of the frame <--- where the door closes.
All you have to do is open the door and kneel down in front of the washer. Now, with clamp in hand, work it back into the groove around the outside lip of the boot. Here's the thing you have to know... That spring? It MUST be located at the 6 o'clock position! So when you are putting this thin back, just make sure the spring is located properly.
The reason? Frankly, I don't know. But the Kenmore/Whirlpool service repair manuals say so! So that's what I do, HA!
Anyway, If you don't replace that clamp and you continue running your washer that boot will dislodge from the front panel. Know what happens then? Call Noah, cause there's gonna be a flood.
Hope this helped you! If so, would you please be kind enough to rate me? Thanks!
SG
May 23, 2009 | Kenmore HE2 Plus Front Load Washer
Dryer just quit heating
First-***DISCONNECT THE ELECTRICITY***. Open the back of the dryer. The element will be in a flat metal tube running from the top to the bottom of the back of the dryer. There will be a few wires connected to it. Mark where these go for reassembly. The heater wires are inside the tube. The whole assembly comes apart quite easily to replace the element. It looks like a stretched out spring.
May 02, 2009 | Whirlpool LER5636L Electric Dryer
2001 Grand Caravan #4 Misfiring
if it's only one cylinder... bad spark plug wire or spark plug would be suspect.... swap the plug wires from another cyclinder... at the coil pack and plug and see if the misfire has "moved"
Robert
Jan 20, 2009 | 2001 Dodge Caravan
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
