Question about Alpine CDM-7854
Hot to turn aux input on?
Cable aux in
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
Does a pioneer deh-p550mp have an AUX. jack on the back or a set of AUX. RCA's to connect a device?
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio and scroll through the sources and make sure it is there.
5. buy cable and headphone to rca cable
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
Oct 06, 2009 | Pioneer DEH-P550MP CD Player
Hi, I am trying to get the aux input to work and am wondering which set of rca outputs to use, front, rear, or constant level? I have not been able to find out which one to use from my manual. I have...
There is either a headphone size jack on the back labeled aux or a blue square plug. If it is the headphone jack then you need a 3.5mm to 3.5mm cable. But if I remember right you have the blue plug and need to buy the auxillary adapter. Then you need a 3.5mm to rca cable. The outputs are only outputs not inputs. Turning the Aux on in the menu does bring it under Source now.
Jul 06, 2009 | Pioneer DEH-8000R CD Changer
Aux cable stuck in Aux input
needdle nose plyers or you can use a screw just turn and pull
Jan 25, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Alpine CDM-7854 Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
