Question about KitchenAid Refrigerators
Ice maker is not making ice, doesnt seem to be getting any water?
    Sergeant:
  • 212 Answers
If no water in ice maker then your inlet water valve on rear of refrigerator is bad.
Posted on Jun 21, 2009
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
My ice maker doesnt make any ice
check fill tube in back to make sure no frozen ice obstructing water flow... also make sure you have a clean filter on unit or it has been changed recently.... there are normally dual water valves on these models... one will work dispenser and one will work ice maker make sure your getting water to ice maker itself... if you are indeed getting water it just will not dump most likely you have a broken gear motor orthe heater in the ice maker has failed.. get another ice maker ....
Dec 31, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice make has stopped making ice
Try filling the icemaker with a cup of water where the ice is made. Make sure the shut off arm is up. wait like a day. if it does make ice then you water valve needs to be replaced. if it doesnt replace the ice maker. also dont forget to check the tube behind the ice maker. it feed the icemaker with water. if that freezes up then water cant make it to the ice, thus ice maker and valve are fine. get behind the frig at the upper top right behind where the ice maker is but outside back. there is a tube that can be pulled out that is the feeder tube make sure no ice, do this ok?
Mar 27, 2010 | Refrigerators
I cant get my ice maker to work. doesnt seem to be getting water
you have solved your own problem?just ask yourself why? sometimes if you go on vacation or not use your ice maker for a while it will freeze up right back to the water supply.try a little hairdryer to the water supply or make sure its getting water.adrian;;;;
Nov 09, 2009 | Kenmore Refrigerators
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Ice Maker dont work
If tray is empty lets fill with water from tap and wait to see if it freezes and dumps. If yes and don't refill then I need the model number so I can help you better. It may need a water control valve or a thermostat, Thanks, Se Breeze
Jun 18, 2009 | Montgomery Ward Refrigerators
Does not make ice
You must check whether or not you are getting water. Disconnect the water line to the water valve located in the back of the refrigerator. If, you have water from the supply , then you may a defective water valve. Changing the ice maker is usually the right move. The kit comes with a new water valve and head. Just to make sure. Check the water supply tube to the ice maker in the back of the freezer. If , it is frozen then no water can come through. If, it is frozen then you definitely have a water valve problem.
Jun 17, 2009 | Frigidaire GLRS237ZA Side by Side...
Ice maker makes ice but doesnt kick it out
seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not workin
ok as far as the water in your door goes sounds like the micro switch is getting a little gummy and sticking this happens when people dump ice in sweet drinks and some splashes up locate the switch and spray a little wd 40 on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
71 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
