Question about Fellowes DM8C Cross-Cut Shredder
I have a DM8C that only runs for a couple of seconds at a time and then it stops. Toggle the switch back and forth and it feeds a little at a time until the page is completely shredded. It works okay in reverse. Help!
  • 328 Answers
Common solution is to clean upper and lower sensors with cotton swab. If it still jams, then you will have to remove the top carefully and clean all paper shreds out of the housing. The paper shreds are most likely packed in the housing shroud and jamming or overloading the motor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
My whirlpool gas dryer stops running.It stops with heat or no heat.I have held the door switch with the door open and it still stops.Sometimes it will run a minute sometimes a few seconds
If it runs when you hold the switch but intermittently when the door is closed, you might need to either replace the switch or the toggle on the door. See if you can bend or adjust the toggle on the door that closes the switch to fix it or if you can't, try replacing it first since it is the cheapest solution. Switch, based on what you posted, sounds fine. Who knows, maybe one is simply depressed from slamming the dryer door closed too many times?
Jan 15, 2018 | Whirlpool Dryers
Lincoln hd 140 barely sparks
Try switching the a,b,c,d back and forth a couple of times a corrosion builds up and causes a week contact so there isn't enough voltage to work . This has happened to me a couple of times . The first time the fan was running and I had no wire feed action and then a local repair guy told me that corrosion is very common with the portable Lincolns . You shouldn't even have to take it apart to clean it just switch it back and fourth and that does the trick. Good luck.
May 06, 2014 | Lincoln Electric Lincoln Easy MIG 140...
STARTS AND RUNS FOR 30 SECONDS THEN SHUTS OFF, STARTS AND RUNS FOR A COUPLE SECONDS KEEPS DOING THIS. I SUSPECT IT HAS A THERMAL SWITCH. WHERE IS IT? CAN I WIRE AROUND IT?
Hi
Yes I think you may be right, it could quite well the thermal switch,"pressure controlled on/off"switch and is not properly set up, minimum and maximum stop/start.
If what I see in the photo, the pressure switch is beside the top tank with a pressure gauge on it, and the electrical supply should feed into/from it.
Hope this gives you a little food for thought, and hope that it is a little helpful
Cheers
John
Jul 19, 2011 | Clarke Power Products AC2002A 2 Hp Air...
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
Paper won't feed
You most likely have a little tiny paper jam in the roller. Your best bet is to remove the screws and very slowly pull it apart so no parts are moved or fall out. then just take your time and look around for the jam and remove it.
Aug 12, 2010 | Fellowes DM8C Cross-Cut Shredder
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Zoom button does not work
Go get some Electronic Contact cleaner and on the Side of the Toggle switch spay a little bit in the front and rear of the switch ,Make sure the Battery is out and spray the rocker up underneath to get to the Tact switch,Rock the rocker back and forth several times to clean the switches,The Contact clear will dry quickly,After dueing this let dry for 5 Min put batt and try it good luck Let me know if this works ttech
Jul 24, 2007 | Sony Handycam CCD-TRV16 Camcorder
Fellowes DM8C Cross-Cut Shredder Logo
556 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
