After washing it can't expel water. - Washing Machines
  • 6,784 Answers
Hi, this is a drainage issue. check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 21, 2009
Is it normal to have some standing water in a washing machine
No. The impeller is below the drum so that all the water is expelled.
Jul 30, 2014 | Washing Machines
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Where can can I pour water for washing cloth?
sir/madam, you cannot
pour water for washing cloththere will be a pipes at backside of the washing machine.one of them is used to expel waste water while other two is used to get water hot water and old water of color red and blue respectively,
Dec 28, 2012 | Washing Machines
Washing machine will not change cycle. After wash cycle will not change to expell water from bowl to go to rinse cycle.
Sounds like the lid switch is bad. What is the make and model number of your unit?
Oct 02, 2011 | Washing Machines
Our Fisher & Paykel Smartdrive LO8 washer has been working great until yesterday. When going through it's cycle it kept pausing when expelling the water. When it got to filling or agitating it operated...
Try a rinse cycle 12 minutes only to see if it does that. If it is a case then the is some clogs up at the drain path. Need to remove the bottom plate with a lot of holes to clean up. Good Luck.
Jan 02, 2010 | Washing Machines
New inglis washer expells water when fills
seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Jul 18, 2009 | Whirlpool Inglis IP4400 Washer
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
Can't expel water
maybe jammed water pump
Jun 21, 2009 | Washing Machines
Washer will not expel water
yes. replace the drain pump motor.
Jan 04, 2008 | Kenmore 43142 Front Load Washer
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
