SOURCE: Samsung V25 Laptop When it is
the screen's connector has worked itself loose from the motherboard. disconnect keyboard, remove screws holing the long blue plastic section just above keyboard; on the left you'll see screen connector, just push it firmly home.
SOURCE: to factory reset my samsung v25 laptop
Let me know the password error appears in your window?
SOURCE: Laptop screen too dark when used with battery
Are you using vista or xp?..The laptops to conserve power will dim the screen , you can , however, change it to brighter by pressing the "fn" key which stands for "functions"key. while pressing that, you should have another set of keys either to your right or obove your left finfers with the symbol fo a sun with arrows pointing up and down..press the fn and tap the up arrow key to increase the brightness.
Let me know if that works
SOURCE: restore factory settings for my samsung r519 laptop win7
system restore can do this for you if windows does work
if not recovery disc are sold on line through ebay and other web sites
