Question about Remington Polesaw Wizard
Chain needs to be sharpend
What size of file neaded to sharpen blade on remington pole saw
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Look at the chain, theresa 3 there and that number coinsides with file size
Posted on Jun 21, 2009
How to clean a POLE SAW BLADE?
  • The first and foremost task is to clean all the impurities, dirt and tree debris. You can do it with the help of wire brush. To remove the oil residue, brush it with a rag or toothbrush and degreaser.
  • Many people prefer citrus cleaner over oil. A citrus cleaner is a versatile cleaner that can be used for cleaning anything in your house.
  • If you are using any degreaser product, mix it with water in a container and put the blades into the container.
  • Let the blade soak into the water for few minutes, scrub it with a rag, rinse it properly and let it dry or wipe the water from the blades.
  • Disassembling the pole saw is required before you clean a pole saw blade and put the blades in the container. For this purpose, remove blades from the pruner. You can take expert's help for this or unscrew the blade.
  • Put the blade on a table where you would clean the blade and keep the edges facing up.
  • Take a sharpening rod and push it forward only between the two teeth. This will file away the meat and sharpen the blade. Keep doing this for few times until you see the filings being developed on the back side of the blade. Make sure to file all the teeth on the blade.
  • The back side of the blade should be rubbed with a file as well. It is required to remove the burrs from the blade.
  • After sharpening coat, the pole saw blade by spraying oil on it to prevent rust and corrosion.
Do not forget to sharpen the blades with files that fit appropriately in the teeth. Diamond and whetstone files are being widely used for filing. So, this is how you can clean a pole saw blade and maintain it also. It does not take much effort. Invest your time to avoid replacing your favorite pole saw in the future.
Apr 07, 2018 | Crafts & Hobbies
How do you sharpen the blade?
go to where you bought the saw and they sale kits and it explains how ti sharpen the chain
Aug 11, 2014 | Remington 10" Electric Pole Saw Chain...
I sharpend my chain and filed and flip the bar around. And it still want cut. Do I need a new bar and chain?
I dont me to be rude but two things spring to mind, firstly have you put the chain on backwards? the chain on the top of the bat should have the sharp edge facing away from the saw ( turns clockwise as you look at it from the side of the saw ) and secondly have you sharpened it correctly ( right angles, and taken the depth gauges down to the correct hight ) there should be no need to replace the guide bar, at worst a new chain will do, let me know if you need to know more about chain sharpening.
Feb 16, 2012 | Garden
Does the blade ever need to be sharpened or replaced?
A chain saw blade requires sharpening often. It can be in as little as 20 minutes if your cutting a very hard wood. Even less if you happen to allow the blade to be used in dirt.
Here is a video to help you use a "file guide" to sharpen your blade.
^^^-- note the videos on the right side of the video that is playing.
This is the most commonly available file guide:
Oregon Scientific Oregon 7/32" Chain Saw File Guide with File #25892
http://www.google.com/search?hl=en&safe=off&rls=com.microsoft%3Aen-ph&biw=1003&bih=587&tbm=shop&q=Oregon+25892&btnG=Search&aq=f&aqi=&aql=&oq=
Thanks for choosing FixYa,
Kelly
(Another video below)
Jun 12, 2011 | Remington Electric Chain Saw
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Apr 18, 2011 | Husqvarna Garden
Wondering what size file to use to sharpen an MCP1510
McCULLOCH MCP1510 is not a good pole saw. You can't easy to use with this pole saw. If you want to find the best pole saw in 2018 go to the https://thebestpolesaw2018.yolasite.com/
Jul 25, 2010 | McCulloch 10" Electric Pole / Chain Saw
Lost manual, need to know what size file to sharpen chain for Remington M30016AW chainsaw.
Your OM, pages 15 and 16. Top of 16 says 5/32s round file.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Remington 16" Electric Chain Saw Assembled...
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
Need new saw blade part no & size for remington model 104316-04
The part you will need is the 8SB. You can call Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps!
May 24, 2009 | Remington Electric Pole Saw
How do I attach the saw to the pole for a Remington M30016AW?
Remington did not make a pole for this saw and any pole that are out there cannot support the size and weight of the 16" chain saw you have.
Apr 24, 2009 | Remington Polesaw Wizard
Remington Polesaw Wizard Logo
410 people viewed this question
Top Remington Garden Experts
roeb
Phil Walker
Phil Walker
Joseph Mueller
Joseph Mueller
Are you a Remington Garden Expert? Answer questions, earn points and help others
